Artboy
Active member
Hi all. This will be a slow build by a noob but I will value all advice. Inspired by zz's Packard, I have started the long road to doing something with this pile of rust. The laws in Western Australia are tough and I am still learning but they don't seem keen on rat rods. I figured I would start by firming up some of the rustier bits of tin after I remove fenders etc. I figured it would be good to firm it up while it is still on the chassis. Following zz's advice I have been recording what I consider to be important measurements. I have also started removing rotten wood which isn't fun - it is early autumn here and temperatures are high 30 degrees c - over 100 in Fahrenheit. Hotter in the shed! Anyway, here are some shots of the starting point.
Someone had ripped the radiator out and wrecked the grille so I need to fix that up. As you can see , the timber connected to the frame on which the body sits is rotted. Seeking advice on how to deal with that. Obviously needs to be replaced with metal but not sure how?
