1931 Desoto with a hemi...
kelseydum
Jul 9, 2007
860
Little Rock, AR
Guess its time to start a build thread. Here we are getting the body off the frame.
Got the chassis broken down. Started welding up old bolt holes up front and started the center x member. Ill get some more pics up today.
Decided to make my own front crossmember out of 4x4" square tube for the airbag set up. This should also drop the body a couple inches from the original crossmember. Still have to notch it for the cups... Should look pretty clean when done. Everything is measuring and lining up really well so far so I must be doing something right thus far.
I think I need to find some bigger cups. These are 5" OD and I need at least 5" ID for the bags I want.
