Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Undead Sleds... makin' old tin Undead every day! > Rat Rod & Hot Rod Talk
Old 12-02-2018, 08:33 PM
tomtbone's Avatar
tomtbone tomtbone is offline
Default Neutralizing Gas
So I have a original gas tank on my 29 Model A, which I want to keep in place.
I would like to neutralize the fumes without contaminating the tank.
I have seen that steam might be the way to go?
Your thoughts, Thanks
Old 12-02-2018, 09:03 PM
using a vehicle outside stick a hose connected to a running car's tail pipe, and the other end of the hose into the tank and let the car run until all the gas has evaporated.
between the heat of the exhaust and the carbon monoxide, it should be safe to clean and weld on if need be.
Old 12-02-2018, 09:18 PM
lowbudget50's Avatar
Are you just wanting to get rid of the smell or repair it?
Minterfab.com
Old 12-02-2018, 09:27 PM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Default My 2 cents
Pump the tank with CO from a running engine a.few min the put some fire in it, i use my plumbers tourch. It may pop but you won't die. If been doing the 48 yrs i've been a firefighters.
Some will say i'm crazy, and they would be right.
Good luck and have fun
Be Safe
and
Be Creative
Old 12-02-2018, 09:40 PM
phil cottingham phil cottingham is offline
Location: Fairhope, AL but originally from Centreville, AL.
You can also use the exhaust off you lawnmower or other small engine.
Old 12-02-2018, 09:57 PM
tomtbone's Avatar
Grateful, makes sence!
Thanks!
Old 12-03-2018, 07:09 AM
kenny c kenny c is offline
My first thought was Beano . On a more serious note, I use a shop vac to blow fresh air into a tank to eliminate fumes and then I blast in some argon or CO2 to be on the safe side before welding. Do not suck the fumes through the shop vac or you will risk a fire because of the sparks from the brushes in the motor.
Tetanus Tornado 49 F6
