Wood is good.
:eek: Oh the pic thru me cause it's turned around backwards on the boat :p:rolleyes:
Yeah. The upside down and backwards thing get me sometimes as well OI. [S :eek:
What you see in the picture is the stuffing box for the prop drive shaft.
While the wife is out door boating. I'm indoor boating.[ddd
Installed the 2 support planks on either side of the keel. Bedded and screwed in. All coated with 2 coats of CPES.
On to the chines tonight as the weather is currently perfect for laminating.
Chine work.
The new chines will be made of 3 pieces of lumber laminated together.
Since this piece goes from narrow to wide to narrow again the outside piece only goes back partway.
Once laminated I will feather this outer piece to match the width of the old one.
Prepping for the chine lamination
Using old shower curtain liners.
Perfect weather for laminating.
2 of the 3 new chine layers glued and clamped. I will add the 3 layer after this sets up as boards this long with epoxy on them are really slippery and hard to hold in place while clamping.
Laminated the 3rd layer on the new chine today.
NOW back to my chair.[ddd
Clamps off then back on again.:eek:
Started the lamination of the other chine.
Hot and humid here today but got it done.
[P
I check here every day. Nice work.
My older brother used to do this from time to time when I was a kid.
When seen first hand, you appreciate how much work this is.
Thanks guys.:)
Finished laminating the PS chine this afternoon.
Once cured I will start to reshape both sides.
Unclamped the PS chine this morning. Pulled out the palstic sheeting and clamped it back on with a few clamps.
It will sit this way until after thanksgiving.
Been a while.......
Back on the boat....FINALLY.
Trimmed the intermediate frames. They are ready to be steam bent.
Did a scarf joint for the final chine piece on the SB side.
This will get laminated to the existing 2 ply's making the chine 3 ply's it's entire length.
Next up is to rip another long piece to finish up the PS chine. More scarfing and laminating there as well.
That's all for now.....
