Corsair
This may *not* qualify as a tech tip, as I am seeking advice:
I have a 1950 F1 with a straight axle and 455 Olds power (exciting times, its just been safetied and licenced - pics to follow). I dropped the front ride height by mounting the axle over the spring. The rear was done the same way, but the drop is not as severe, so the stance is noticably nose down.
Problem: Its down too low in the weeds, with the front bumper only 8 inches off the pavement. Its low enough that the shocks essentially don't do their job. The ride is rough as ______.
A couple of ways to correct this:
1. Forget about the drop, put the axle back in the stock position. This will gives me a slight nose-up, mild gasser look. May be quite nice.
2. Get some big coil overs for the front end to give me a couple of inches.
3. Make up some custom spring hangers to gain a few inches.
The last one might be the best, because it'll still give me the most choice in determining the ride height.
Please vote for 1, 2, or 3... or give me your opinion on other possibilites...
Many thanks,
Ian
Many thanks,
Ian
