Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Electrical... Talk & Q&A!
Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 10-12-2019, 10:55 AM
Burgerman's Avatar
Burgerman Burgerman is offline
Also curious. Have not seen such a wobble before. Agree with the bench exam suggestion. Any way to see down the hole with a light and examine the drive gear or feel it for play
Old 10-12-2019, 03:19 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Drive gear is the cam. Didn't do this afaik with the points dist or the previous Duraspark.
Old 10-12-2019, 04:41 PM
Originally Posted by Old Iron View Post
No problem, I never take a discussion that way
Good!
Looking forward to your findings, Bama... looks like the tail is wagging the dog... if the shaft isn't bent, maybe the gear is drilled off center?
On the positive, looks like the carb works!
Old 10-12-2019, 06:54 PM
Bamamav's Avatar
Yeah, it's funny, dang thing runs great! I'm scared not for long though, something would wear out quick like that. I've got to replace some freeze plugs while it's out, so I'm thinking about re-ringing it and some new bearings, timing chain and sprockets, and gaskets. Should last a long time if I do that.
Old 10-13-2019, 10:44 AM
"Looking forward to your findings, Bama... looks like the tail is wagging the dog... if the shaft isn't bent, maybe the gear is drilled off center?"
Another good thought!!!!!!!!!!!!!
