threaded inserts
24dodge
One of the Dodge brothers
May 18, 2007
1,103
Jupiter Florida
I needed to mount some stromberg adaptors to my manifold , but I wanted to mount them front to back so I could use a progressive linkage . the way the manifold carb mounting holes and the adaptors lined up would have required the carbs be mounted sideways , the adaptors had holes drilled in them on the sides but were so close to the throat there was no way to get a bolt in there even a socket head bolt , I found these threaded inserts at Grainger , they`re called ezlok inserts, these are 3/8-16 outside 1/4-20 inside but they make them in lots of sizes , made me happy that I didn`t have to grind up my new parts to get the clearance I needed.
Really kool!
24,
Man, that looks really kool... can't wait to see it all put together! Thanks for hte tip!
