Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007!
Go Back   Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Tech Tips!
Old 11-06-2017, 06:22 PM
exador exador is offline
Default not tech but 1/2 assed
Cold weather here in SW Ohio brought back one of my half ass things I have done to my cars over the yrs. 73 now.
An old 31 pontiac coupe ( just and old car then) did not have a heater and girlfriend would not shut up about being cold. Solution was to put in a heater. Being one of the kings of shadetree this was not hard.
Got a heater core from a friend. Used plumbing strap with strips of rubber I made mounting brackets. Mounted core, plumbed and bingo we had heat. Well almost. Took core out, made cardboard box around the core. Sealed and covered with "scotch tape". Then took and old flannel shirt and sewed around it, wazoo, heat. Female complaint, too hot. Open window, too cold.
I got an old ball valve made a bracket to hold and cut heater hose and mounted on valve. Drilled hole in lever on valve handle, took long piece of small dia. rod bent a 90 degree at one end, hole for cotter pin in rod. Run thru firewall. Now I could open or close to get comfortable heat.
When a kid in late 50`s and early 60`s and 16 with very little $$$$ ingenuity and a shadetree solved many problems.
Old 11-06-2017, 06:31 PM
akatao akatao is offline
Thumbs up
Old 11-06-2017, 06:33 PM
sneakysnake's Avatar
sneakysnake sneakysnake is offline
"There’s nothing new in originality"
'Necessity is the mother of invention"
'46 Build Link
'53 Build Link
"Its a catastrophic success"
Old 11-06-2017, 07:15 PM
smallfoot's Avatar
WHAT???///??? You mean that's not the way you run a heater system???///???
Old 11-07-2017, 09:16 PM
kenny c kenny c is offline
Makes perfect sense to me.
Tetanus Tornado 49 F6
Old 11-08-2017, 05:05 PM
Skip's Avatar
Skip Skip is offline
That sounds like the basic setup for any simple heater. Love it!
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
