Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#2201
#2202
If you got a 4.3 motor the tranny could probably work unless it was something you just didn't want. 4.3 same as sbc bolt pattern.
#2203
![]() Quote:
The rear axle can be adjusted with an adapter plate, with a pin on it, that hooks over the stock spring pin, and relocates the axle. These are available for centering the axle on an S10. I am sure you can make one to your specs. You will most likely be softening up the rear springs anyway. You are lucky to have a pattern for setting up the body mounts on the new frame. You should be able to get some serious rubber under it now. You may need to tub the rear. Stock S10 rear is good up to around 400HP.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459 1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231 The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while. Not taking anything too seriously. ![]() |
#2204
![]() Quote:
First S-10 lesson learned. It is supposed to be a 4.3. Claimed to run but missing the radiator and the altenator. I wast't really concerned in regards to the motor. Just the condition of the frame. But if the Trans will work with a SBC V8. So much the better. I'm going to try to get out to it tomorrow for a close up look see. This was another great FB market place find. He sent about 2 dozen pics of the frame and although surface rust. no rot. For $300 delivered(in 18 degree weather) i think I will be fine. Of course I will also use the MC brake pedal and parts of the column. I think it has buckets in it so I may be able to peddle those and a few other things to get some money back. Hopefully some up close pics tomorrow. Torchie |
#2205
![]() Quote:
I have heard of the relocating plates for the rear axle. I will be putting a SBC in it. I would have liked all MOPAR but at this point just to get the body down on a running frame would be huge. I'm sure there will be a need for some ride height adjustment. Not looking to fill the back wells with tires in fact I'm leaning towards running the stock Dodge steel wheels (As I now have 9 of them) with some period correct wide whites and the 50 Olds wheel covers I have. I will require adapters to go from the GM bolt pattern to the Dodge. Torchie |
#2206
Great score Torchie, one less thing to worry about.
Glen My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026 Don't give up, it's far too much fun once you can drive it. |
#2207
Cold as my heart outside again today but i got out to the donor S-10 with no Torchie's being hurt in the shooting of these pics.
4.3 V6 as told. So it should have the 4L60E trans. Missing the altenator. radiator and distributor. As told. Couldn't get my fat hands down in to see if I could turn it over. Checked for things I could strip off it to resell. Looks like there will be some stuff. So after spending the morning researching I'm considering just using this V6 in the Dodge. If I get it running. My reasons. Cost effective. ![]() Durable engines. ![]() Less work.Thank you very much. ![]() And it would make it different ,yet again ,from the many customs being built out there. I love a throaty V8 as much as the next person but if I hope to get this thing even rolling in my life time things have to go easier and quicker. And based on what I've read I can do some fairly reasonable add ons to wake this engine up a bit. As always. All thoughts and opinions are encouraged. I've already learned a lot this morning which is what helps me to keep the brain cells from decaying. Torchie |
#2208
Lookin' good.
#2209
I've still got some 4.3 engine parts around here Torchie, think I have a distributor or two, but not sure what model, 88ish maybe. When it gets warm enough to play with it, I can look and see what I have and if you can use it, I can send it your way., for the shipping costs. I know I'll never use it.
2021 calendars available here: https://www.zazzle.com/2021_rust_and...83162245916713 |
#2210
I drove a S-10 with a 4.3 for years and liked everything about it. It towed my dragster and the Crosley with ease. It will be fine in a custom cruiser.
Bookmarks |
Thread Tools | |
Display Modes | |
