made some progress on my truck
joehalford01
'Vette brake specialist!
May 16, 2007
1,779
Visalia, CA
I pretty much finished the battery install on my truck. It was originally behind the cab in a tool box. I had to order a stock style tray. I couldn't find a negative cable locally that was long enough to run it nice and clean like i wanted so this is a temporary set-up. I will probably order one soon from summit.
This is where i attached the negative cable for now, Is there a main grounding strap on these motors or do they ground via the motor mounts? I didn't see one but then again, i didn't look that hard. I've been pretty busy.
(ignore that red wire, it's gone now)
the previous owner put them there to cut the water supply off to the heater core in the summer. I think i'm going to do away with them eventually, just havn't got around to it yet.
