Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Traditional Style Hot Rods
Traditional Style Hot Rods A general and broad section about "Traditional Style" rods!
Old 04-09-2018, 12:46 PM
forbigpicture's Avatar
forbigpicture forbigpicture is offline
Please stand by.......
I like the carb and intake setup too....
Old 04-09-2018, 06:48 PM
Hombre's Avatar
Hombre Hombre is offline
Thanks guys I have had the intake for a pretty long time. On the early Hemi's there were some that had what I call wet heads. Another words they did not use the water manifold that bolts to the front of the heads, that also houses the thermostat housing. Instead they used a intake manifold similar to a Small Block Chevy that has the thermostat housing on the intake. Trouble with that set-up is no one makes manifolds for those heads anymore. This old Drag Star manifold has provisions for the water to go into the heads up under the carbs.
I bought this old manifold at a swap meet years ago knowing that someday I just may be lucky enough to have a use for it. The Large logo Stromberg 97's took a little more finding but in time I found enough of them to build these six.
Stromberg's are actually pretty neat carbs. They are very simple and easy to rebuild, it ain't cheap but the actual rebuilding is pretty simple if you know a couple of tricks.
Thanks again folks
Protected people will never be able to understand the intensity life can be lived at. To do that you must completely and totally understand the meaning of the word "DUCK"
Old 05-19-2018, 09:21 PM
lowbudget50's Avatar
Love the carb setup!!!!!!!
Minterfab.com
Old 08-20-2020, 01:05 PM
gasser's Avatar
gasser gasser is offline
Hemi looks good in everything. This is one of mine 1963 F100
File Type: jpg 8CA6FDDE-CCB8-4E73-8F53-9DAB9FACFC70.jpg (86.6 KB, 35 views)
Scrub Line: The point where the roof of the car hits the garage door opening
Old 08-20-2020, 11:13 PM
'Om that upholstery made me go back and reread where you said you did it yourself! Wow.
Disclaimer-no rats were harmed in the construction of this vehicle
Old 08-21-2020, 09:42 AM
Good job on hunting up the desirable parts. Really nice work too.
Old 01-03-2021, 10:08 AM
biggeorge's Avatar
biggeorge biggeorge is offline
Thanks again folks
That's a nice set up, i have been looking for an affordable tri power one for my 1954 331. In this case low production means high dollars
1930 Buick 5 passenger coupe
Looking for a nice original 50's to early 1960's Buick or Oldsmobile convertible.
