Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice  since 2007!
Go Back   Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice since 2007! > Questions/Suggestions
Questions/Suggestions Questions or suggestions about the forum... don't be shy!
Old 02-05-2017, 10:27 PM
rvreddog rvreddog is offline
Default Ignition lock
I picked up a 2000 chevy truck as a doner/parts truck for a future project,but I didn`t get a key with it.The question is can I just drill the lock and use a screwdriver for a key to see if it runs?I`m sure I can with a Ford but is the Chevy pretty much the same lock setup?
Old 02-05-2017, 11:08 PM
It depends if that year truck had a chip on the key. I would press the person you bought it from to find the key!
Old 02-06-2017, 01:07 AM
soltz's Avatar
soltz soltz is offline
The Rat Captain
Question
I'm a ford guy but built a gmc, mine was an early model, i pulled the wheel off and made access to ignition switch/lock, one small pin holds all together.
Hope this helps, but i may be wrong,
Be Safe
and
Be Creative
Old 02-06-2017, 06:58 AM
The pin is right but to change the cylinder you need to rotate the key to the start position,kinda hard to do without a key.
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
