Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 07-31-2018, 10:53 PM
offroadrolls's Avatar
offroadrolls offroadrolls is offline
Default toe in question
Where is toe in measured from? If the spec says "1/8" toe in" is it supposed to be measure from the rim or the tread of the tire? I would think an 1/8" at the rim would naturally be more at the tread of the tire and visa versa.
Hot things look just like Cold things
Offroadrolls build:
http://ratrodsrule.com/forum/showthread.php?t=23696
42 Chevy PU build:
http://ratrodsrule.com/forum/showthr...ht=42+chevy+pu
Old 08-01-2018, 07:49 AM
The alignment shops use to use the rim, If they still do.
I made a toe bar tool out of 3/4"x 3/4" square tubing. It has two 12" vertical pieces and a 6' long horizontal. They are welded together to make a long U shape
I put one side against the rear side of a tire and measure the other then, move the tool to the front side of the same tire and measure the other side.
This measurement will be 1/8" more than the rear to get 1/8" toe.
Old 08-07-2018, 11:49 PM
donsrods's Avatar
donsrods donsrods is offline
Yep, I just run a tape measure at the very back of the tire and then set the front to be between 1/16th and 1/8th of an inch less. That gives a pretty close toe in for a straight axled car. I measure the actual rubber of the tire, not the wheel, and I pick a tread to use as my measuring spot.
Old 08-08-2018, 11:08 AM
ditto, donsrods
Old 08-08-2018, 11:46 AM
MercuryMac's Avatar
Builder Junky!
I also use the tire tread to measure from.
Old 08-08-2018, 07:35 PM
smallfoot's Avatar
Tread measured here too...
Old 08-08-2018, 10:41 PM
Tread would be the easiest.
I made the tool when I was asphalt circle trackin. The slicks didn't have tread
