3.25 rear-end gears VS 3.5O rear-end gears performance question
skull
''SARCASM: just one of his many talents.''
Apr 12, 2009
5,905
wet side, washington state
0K , the housing is leaking in the 193Oish mopar thingy, it is egg shaped where the pinion goes thru and cannot be rebuilt::(
l have chance to get 3:5O's to replace the 3:25's in her now. don't know if their posi but chances are they ain't.
the question is how much of a performance difference will it make ..[S
the car weighs 24OO and right now gets 25mpg will go from O to 6O in about 4 seconds with the 3OOO stall, 375HP and 31 inch tall tires.
it's a blast right now, will the gear change affect it much?
somewhere there is formula, but l can't find it.
l did circle track stuff most of my life when the family raced and set up for the straight line is totally different and honestly l don't know much about it.
just wondering if it is worth the change or just find a 3:25 and stuff back in it.
the gas mileage will probably go down a bit, but l think it will respond quicker off the line and still be a blast to drive.
thanks in advance,
Later :cool:
I switched from 4:11 to 3:73 in the Chevelle, made a big diff but mainly on the highway! RPM's went from 3500 to 2100 at 70mph, made cruisin' much more comfortable. Thinking about going from 3:50 to something closer to 3:00 in the Nova.
You'll gain about 7% RPM's at the same speed with the 3:50's. So if you're turning 2500RPM at 65MPH now, you'll be turning nearly 2700RPM with the gear change.
I went from a 2.79 to a 3.00, about 250 more rpm at 60 mph. Didn't really see much fuel mileage difference. It did take off a bit better though. I may put my 3.55's in when I get the AOD in.
Thanks
thank you guys[cl
so l am going to go ahead and change them if my friend comes thru with the 3:5O's he thinks he still has somewhere, talked to him last nightand he's looking for them. sounds like the rest of us, l got'em SOMEWHERE 'round here
well, a bit more ZOOM off the line will be fun, interested to see how much the change shaves off the O to 6O times.
right now at 6Omph the tach says around 24OOrpms so it will likely go to 26OO/27OO and l can live with that, probably from what you guys are stating l may lose 1/2 mpg.
Later :cool:
If someone changed them and didn't tell you, you might not even notice the difference. I went from a 3.70 to a 3.50 in the rpu and the only difference I could see that I couldn't get 4th gear scratch any more.
