Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Electrical... Talk & Q&A!
Electrical... Talk & Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 10-26-2020, 11:42 AM
DozerII's Avatar
DozerII DozerII is offline
Default Coil suggestions
I running the stock electronic Dodge distributor on the 440, instead of using the crappy Dodge lean burn electronic ignition, I'm using an Accel GM electronic module. I'm having trouble finding out what coil I should run with it, any suggestions?
Glen
Old 10-26-2020, 04:34 PM
Dr Crankenstein Dr Crankenstein is online now
GM's HEI coil spec is 0.5 ohms primary resistance. Anything higher will limit voltage output. Stick with .5 and you'll be good!
Old 10-26-2020, 04:42 PM
DozerII's Avatar
Thanks Doc that's the info I was needing 👍
Glen
Old 10-26-2020, 05:51 PM
My pleasure.
