vauxhall 10 ratrod
maddad
Active member
Nov 20, 2010
29
Here is my bulid i have just stared it's a 1939 vauxhall 10 four door,I have chopped the roof six inches,cut the original running gear out and fitted the body onto a reliant scimitar chassis.I then streched the chassis eight inches to make space for the 6.2 v8 gmc turbo diesel.I have mocked up some picks today with the front bumper and grill let me know what you think
Looks good to me! What you going to do for springs? Your fronts look a little...uh...stiff. Those must hae some tall glass, If took 6" outta my windshield, I'd have little more than a slit!
Cool! It's great that we are starting to see some European builds on here. Never see any car like that in person in the states!
cheers guys
a few more pics,i am still working out how things will fit, i have started on chopping the doors tonight will post some more pics of that jigsaw soon.
Haha took a while to spot ,it will ride a bit harsh like that mate.
going to have to come round again see the progress,took mine out the other day in the wet its lethal.
got a bit more done tonight starting to get the look i am wanting,two doors chopped and tacked back together and they open and close ! still not sure about the front grill ,wot do you think ?
I like the grill dosent look the best from that angle and there is an angry looking man stood near it.
its looking good with the doors done but from that angle it looks like it would look better with massive back wheels like mikey has on his y rod,but from the back those wheels you have on look good sticking right out..
yes but there is a happy chap inside !.I am going to cut the centre out of the rear rims and flip them so the wheels will clear the body when i drop it on the deck.
the way i have the body mounted on the chassis now, when the body is on the floor i still have about 3 inches more suspension travel lower so i can go with a wheel 6 inches taller and still get it on the deck,if that makes sense .bit more done tonight,mm how did i make the doors fit on the drivers side again
got back to it over the last couple of weeks
finished the frame repairs and mods then blasted and primed it.pick up a th400 so i got engine and trans mounts made and fitted.somehow got a range rover rad with built in trans cooler to fit in the grill it was tight !started making up the rad mounts tonight
