vauxhall 10 ratrod
Looking good, you're making great progress! [cl[cl However with the torque that diesel is going to have you may need to consider putting some outriggers on that thing......... to keep it from flipping over ya know:D
got a bit more done over the last few weeks,air and fuel all plumbed in most of the electrics sorted.
glass in ,door bottoms replaced ,heater fitted
heater
The taps are the original 1935 ones i kept when i replaced the bathroom in our house,the radiator is a display model from a plumbing store,works a treat.
cheers for the comments guys. maddad.
Vauxhall 10 rat rod
Had a run out today to try out the gearing on my big rear wheels ,changed them as gearing was far to low and i like the look of the high profile tyres.I stopped to check the wheel nuts and took a few pics.
Vauxhall 10 rat rod
cheers guys !
Tyres are 8.5 x 17.5 truck radials on adapted truck rims ,they have the offset needed to get past the body without big spacers or a wider axle ,It will put more stress on the bearings but the scimitar axle is a strong axle.
