Old 05-31-2011, 07:05 PM
the reverend muddy grimes the reverend muddy grimes is offline
Brother Binder
Send a message via Yahoo to the reverend muddy grimes
its centered. and clears the steering column by fractions of an inch. the problem Im now having is I had to cut the u-bolts on the rear end to drop the old one. seems noone makes them that size anymore. the only place i have found them locally wants $150 for 4 of them, (fastenall, cause they have to custom make them)
http://ratrodsrule.com/forum/showthread.php?t=12335
You cannot tax a society into prosperity
Old 05-31-2011, 07:12 PM
What size do you need?
Old 05-31-2011, 07:54 PM
Brother Binder
8 inches long, 1 3/4 id. 2 inches of thread. smallest i can find at autozone, oriely, or tractor supply is 2 1/2 id
Old 05-31-2011, 08:41 PM
Shea Laking's Avatar
Shea Laking Shea Laking is offline
WOW! That's a bummer!
Do you have a spring shop locally? You know, like works on heavy trucks, etc.
Our local place makes u-bolts for something in the neighbourhood of $50 a set.
Might be worth a check in the Yellow Pages.
Truck's coming along great, BTW. Keep up the good work!
Regards,
Shea
"Just cause you could doesn't mean you should"-Davidhud29
Father,School Bus Mechanic, Home Handyman, Car Lover, Husband-All to varying degrees of mediocrity
Old 05-31-2011, 08:46 PM
I'd get the 2 1/2" i.d. U Bolts and heat and reform them around a chunk of 1 3/4" pipe. Good old blacksmith work. Heat and a hammer will get you there.
If they need to be flat across the top, first straighten them and then form on a piece of 1 3/4" square tubing.
Old 06-02-2011, 04:57 PM
Brother Binder
found a place called TruckPro that made my u-bolts for $35 for the 4 of them. Made me oh so happy. then went to the driveline shop. You figure for $120 they would use new tube or have a pretty weld.
Old 06-13-2011, 06:34 AM
Cool, good news!
Toldja finding a truck shop would be a good idea!
Yeah, driveshaft shops are usually about "git-r-dun" they don't care what it looks like. But, most people aren't building "hot rods" either.
Looks like you're getting closer, great job!
Regards,
Shea
Old 06-14-2011, 05:21 PM
Andrew's Avatar
Andrew Andrew is offline
Cool build!
Old 07-02-2011, 04:25 PM
Brother Binder
hit a wall. Gonna do a frame swap. The stock wone started twisting when I started it up...Oh well. This is why a real car is never finished
Old 07-02-2011, 05:26 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Question box it?
is there any way to box it or reinforce it with having to swap it out?
swapping it sounds like a ton of work.
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
