Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
#131
#132
Learned a lot from my mistakes....think I'll make a few more.... ![]() |
#133
I like everything you've done so far but, I do have some concerns with the bracket welded to your radiator with the radius rods to the cowl. I know how much mine gets jerked around when I hit a rough spot in the road and think you might end up cracking the aluminum. Just my 2 cents
If you make a bracket that connected the radiator and surround together then bolt the radius rods to that It would be better. |
#134
![]() Quote:
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459 1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231 The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while. Not taking anything too seriously. ![]() |
#135
What you said about cushion is a good idea. It would help a lot to have some rubber mounts between the radiator and rods.
#136
I made rubber isolaters for the radiator struts. They should take care of any vibration issues at the top mount. It was in the original plan for this radiator install, but I managed to space it out during my year (?) off from this project. I hope there will not be enough flex in the frame to cause the body parts to bang into the radiator.
Thanks OI. Much appreciate your suggestions. It at least reminded me to do this. I'll watch for evidence of other assaults on the radiator. So, the seat is in. The trans cooling lines are hooked up. The radiator hoses are hooked up. I need to finish bolting on the grille and surround, and install the front turn signals and secure the wiring. Then its fluids and engine noise time again. I hope. I think I see a way to raise the steering column about an inch or so. But I'm going to stare at it some more before I start cutting on things again. In the current location, it is either rubbing on my legs, or completely blocking the gauges.
#137
Skip, I watch my rad and grille shell dance sideways a lot on rough roads because I have no hood on my '36 truck. I was surprized at that, so OI was good to speak up. Your rubber spacers will soften the jarring. Keep on tinkering.
#138
Have you thought about the possibility of a smaller wheel. ( He says. Not knowing what you have on there now.
![]() I myself prefer the look and size of the original steering wheels but it's usually a simple way to gain some space. ![]() ![]() ![]() Torchie |
#139
![]() Quote:
#140
![]() Quote:
Bookmarks |
Thread Tools | |
Display Modes | |
