Old 05-04-2019, 03:47 PM
TruckRat's Avatar
TruckRat TruckRat is offline
Can’t wait to see it finished!
My 40 Chevy truck build
http://ratrodsrule.com/forum/showthread.php?t=36105
Old 05-04-2019, 08:26 PM
Skip's Avatar
Skip Skip is offline
Me, too. Well, in reality there are still things I want to improve on, like the turn signal and tail lights. The ones on it now are temporary. (cheap HF tow lights) They work, but zero class. But for now, its get it together and running smoothly, then take it to the DMV for their blessings.
Today, I got the grille and surround put back on, and installed the temporary turn signal lights. That done, I put it back on the ground, and found a flat tire. Not the best way to lower the front end. So I aired it up and discovered a bad valve stem. Spent an hour looking for a valve stem tool. I know I have several. Finally found a valve stem cap with the tool on it. Changed the valve stem and aired the tire up again. This tire has always had a leak issue. Maybe I finally found/fixed it. I'll know tomorrow.
Tomorrow, its check it all over, add fluids as needed, and get back to seeing if it will run right.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231
The thing about a '39 Ford pick-up is that that ugly grille kinda' grows on ya' after a while.
Not taking anything too seriously.
Old 05-04-2019, 09:34 PM
Torchie's Avatar
Torchie Torchie is offline
Old 05-05-2019, 06:26 AM
DozerII's Avatar
DozerII DozerII is online now
Oh ya [p[p[p
Glen
My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026
Don't give up, it's far too much fun once you can drive it.
Old 05-05-2019, 07:01 PM
Skip's Avatar
Bad words. Bad words. Bad words. But really, things happen to the best of us, and I can't claim that status.
I got everything checked out and couldn't find any more little things that needed to get fixed before adding coolant and cranking it. So, decided to add just water first, just to make sure I didn't leave anything loose. Short story shorter, there is a leak in the front left side of the radiator where I can't see it. So, I started pulling the front sheet metal back off, while thinking "Why didn't I think to do this test before I put it all back together?" Because a new radiator isn't supposed to leak, thats why! Unless I made a hole in it. Or its defective. Or... Well, I decided I am was not in the mood to take the truck apart at the moment. I'll work on it tomorrow after my dentist appointment. Hopefully, its an easy fix. I watched a couple videos on repairing holes in aluminum radiators, and it looks doable. I'll know tomorrow.
Here are a couple pics with the front sheet metal on and the truck sitting on the ground. It will be one or two inches lower when the suspension settles. The last two are my solution for what to do with mangled side panels. Covers the sides of the radiator.
Old 05-05-2019, 07:41 PM
Sorry 'bout the rad, Skip.
Good thing you filled it with water... epoxies and/or TIG welders don't play well with contaminated aluminum!
Old 05-05-2019, 07:45 PM
Skip's Avatar
True story. Condolences accepted. I'm hoping epoxy will do the trick. I'd love to have a TIG, and know how to use it, though.
Old 05-05-2019, 08:23 PM
Had a fan get into an aluminum radiator. I epoxied it, still holding to this day, 8 years later.
Old 05-06-2019, 05:36 AM
BillM's Avatar
BillM BillM is offline
Don't lose your cool now Skip! It's so close and looks really good. Good luck with the rad repair.
Old 05-06-2019, 10:25 AM
Skip's Avatar
No chance, my friend. I'm on this bad boy now. I just knew when it was time to quit yesterday. Dentist this morning, then back at it today or tomorrow at the latest.
