Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Transmission, Rear End... Talk & Q&A!
Transmission, Rear End... Talk & Q&A! Tranny, rear end, drivetrain related stuff... shift it... grind it... pop da clutch!
Old 03-21-2017, 02:58 AM
Nailhead A Nailhead A is offline
Default buick nailhead to chev trans.?
Hey any Nailhead fans,
anyone ever stuck a '57 chevy 3 spd on a '54 322? I have a nailhead I'd like to use but no trans...I have a '57 chev rear axle so the chev 3 spd. (I think they are saginaw??) seems like a good choice. I also have a weak 5 bolt top cover 3 spd closed drive trans from the smaller buick 264 (with a bellhousing that will fit the 322), flywheel, clutch and pressure plate, apparently the flywheel can be reweighted to work with the 322, but the trans itself is weak as hell, has a weird in-out shift pattern that I'd have to make my own shifter for, and is a torque tube trans. Does anyone know if this will work and which mods need to be done?
- Thanks
Did I mention I can't afford (let alone find) an aftermarket adapter
Old 03-21-2017, 07:58 AM
Here's a link to the Nailhead guru Russ Martin
http://nailheadbuick.com/tech-info
Old 03-21-2017, 08:14 AM
Well I just went through the list looking at suggestions on my 401 and looks like the list has been removed or done away with
Old 03-22-2017, 09:45 AM
Torchie's Avatar
Torchie Torchie is offline
I posted the same links as well OI when he asked this question in the Nailhead section of RRR.
I have also pointed him to a FB Nailhead group that Russ and his son are members of. So far no definite answers.
Adapter stuff for nailheads are expensive even if you can find them. Same went for the Olds Rocket V-8 that I had in my truck. Once you start dealing with obsolete engines it can get pricey.
Old 03-22-2017, 10:00 AM
Torchie's Avatar
Here is a link to some adapters.http://transmissionadapters.com/Pricing.htm
The Buick bell housing to GM 4 and 5 speed trans might help you out.
Old 03-22-2017, 10:06 AM
Torchie's Avatar
Here is another link to Russ Martins shop. He has a Transdapt bell housing that takes a 3 speed as well.
http://nailheadbuick.com/transadaptors
Old 03-25-2017, 02:30 AM
Thanks Torchie but $350 US and thats JUST the bellhousing let alone everything else
Old 03-25-2017, 10:18 AM
Does the bell housing off a 401 fit?
