Ammeter gauge wiring
animal
Nov 24, 2011
1,160
Downtown Hooper, CO
I know voltmeters are preferable, but this guy I'm wiring the '56 Chevy for has an old set of gauges he wants to keep and he wants the ammeter wired up. I see on the net to hook one wire to the hot side of the battery and the other side to the alternator. The gauge has + & - on the posts...does the + post hook to the battery?
Yes, you run a #10 gauge wire from the battery to the plus side of the gauge and then a 10 gauge wire from the other side of the gauge back to the big post on the alt. This was a common practice on a 1956 because there was not a lot of things drawing juice in the car like there are today. That is why people use volt meters, they hook up like a light bulb with a small wire going to the volt meter and the other side going to the ground. Wiring the amp gauge the way it is supposed to be if there is a problem like a short in that wire it will burn up everything in that car. With the excess accessories that you have now a days I would strongly convince him not to hook up the amp gauge.
Terry & Lee are correct. You can put the ammeter in but don't wire it. Hide a voltmeter someplace.
There is a way to hook up an ammeter so that it only sees a portion of the current so that it won't overheat, but I can't remember how to do it. There are also ammeters that work by wrapping their pickup wire around a hot wire without actually be connected, like a inductive timing light that you clamp around a plug wire. Might be able to swap the guts to one of those, or better yet, to a voltmeter.
I put SW gauges behind the factory gauge panel in my car, they look like they came in it.
You can wire an ammeter across a load or shunt resistor. The ammeter hooked up like that is actually a volt meter calibrated as amps because the meter is not in line with the alt. It actually measure the differences in the voltage across the shunt/load. Jim
After I posted this yesterday, I found some disturbing evidence of charring around a splice made in the ammeter's wiring.....wait for it.... made with a wire nut.:eek: When I touched it, the wire nut fell off. I immediately got on the 'net, did some research, and found a voltmeter that looks exactly like the old ammeter, other than the name on it. I called the owner, told him I wasn't going t wire up an ammeter in the car, told him about the replacement, and got him on board. I ordered the other gauge and didn't have any nightmares about another '56 on fire. ;)
On my 1st car, 70 Duster, I installed an ammeter. Ran 2 10ga wires through the firewall. Even back then I didn't like it. Jim
