Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 06-13-2019, 10:14 PM
redtailboa redtailboa is offline
i Used 3/8 plate to make the mount , do you think i still need to reinforce the top plate ? The wisbones where just cut to fit the axle in place , I usually just tack weld things first until i have everything fitting nice . Couple pics of what it looks like now
Old 06-13-2019, 10:46 PM
Yes! I like to think of it this way... they don't call it a suicide front end for nothing. On something that important... l suggest gussets! I would put some cool looking plates on both sides of your top plate!
Old 06-13-2019, 11:32 PM
Your perch needs some "backbone" as Old Iron and Blue Eyed Devil said. From fbp's link, this design is far superior to a flat plate, no matter the thickness...
Again, do not compromise the integrity of your wishbones. Sleeve or fish plate as I described...
Old 06-14-2019, 08:18 AM
Blue Eyed Devil's Avatar
Devil's Advocate
do you think i still need to reinforce the top plate?
I don't think, I know.
The weight of a complete vehicle coupled with a working suspension will bend a flat piece of 3/8 plate like BUTTER.
Scale it down for an example - Take a flat strip of sheet metal in your hands. Bends pretty easy on the flat right? Now turn it up vertical and try to bend it - not so easy. That's with your hands and a thin piece of metal. The same concept applies with a heavy vehicle and a thick piece of metal.
Reinforce the perch.
Old 06-14-2019, 10:14 AM
05snopro440's Avatar
The guys are 100% right. I marked up a photo to explain why they're saying what they are. The blue arrow is the force being placed on your steel plate, (in an upward direction), and the green lines are the distance between that force and the next support point. When a force is applied to a component away from the nearest support point, this creates a bending force shown by the red curved arrow (in engineering terms it's called a bending moment). If you held the plate with two fingers (one on either edge) and pushed up on the plate the same distance away, the plate would spin. Since the plate is fixed on one end in your case, you're putting a big bending force into that plate that increases and decreases as the suspension loads on it, which also results in cyclic stress and can result in fatigue especially in a poor design.
Make no mistake, this design needs attention before it can be considered safe, as you are at risk of not only bending the plate but can fatigue and crack it and you're testing fate as it is.
The gussets that OI showed should be added at a minimum.
My '46 GMC on Photobucket
Old 06-14-2019, 04:55 PM
Thanks everyone . My problem is trying to use the front end i bought . I intended on buying a nice front end and brake kit but 1500 US turns in 3000 Can by the time it gets to me . my first design was round perch ,but did not look right ,too stretched out . . So would adding the gussets on top be ok ,or should i redo everything like in the pic posted . The problem is having the spring out front and no travel for axle .
Old 06-14-2019, 05:16 PM
I'm from Canada as well, after you factor in the exchange I'm not sure where the extra $1000 comes from, but I get it. The exchange right now and shipping is killer. Sometimes the cheapest thing you can do is spend money on better parts
Gusseting the bracket you have should alleviate most of our concerns with the design, but as was mentioned you need to plate where you've pie cut your wish bones as well.
