mountain
I was trying to get my drum off of my International S110's tapered hub a while back and I could not get it pop off. So I stupidly put too much pressure on the puller with the hub nut off and mushroomed out hub threads. The only way to replace on this truck is to replace the rear of course. After some crying and tool throwing, I starting trying to figure out what I was going to do. I found this tool called a "Chase Em Back" thread chaser. It is hinged and you start with the good threads and work your way out. I just thought I would share. Hopefully someone reads this before they bugger up their threads. Good luck out there!
MTN
MTN
