1931 Ford Model A Pickup Lakester bound
Thanks Guys
Lots of little stuff to get done before things are picture worthy. Rear floor pan all patched up and lined back up with the cowl. Back of the cab had a lot of bondo to remove and a lot of hanner work. Added a brace along the beltline to stiffen up the cab, rebuilding rear door posts to put the upper part of the cab back on, but still have a ton of bondo and hammering to do on that. may be a couple weeks before I'll have something done that looks like progress.
Some eye candy. Lots of bondo removed from the back of the cab. Test fitted a couple peices.
Moving forward. Got the cut at the beltline that someone did to make this a rpu, almost finished. Then I can move on to cutting the old chop welds out. Boxed in driver side door post and got some of the wood back in.
Looking good Mike. Are keeping track of the hours you are putting in this project? i'll bet it's bunch.
