Gasser rebuild
a few ????
is there really such a thing as a chopped top gasser?:D[S
and a more serious one-- how do you ever plan on getting anything to line up while working on that body setting in gravel--looks like there's no frame or body support-blocks or anything--it will hafta be leveled and squared if you ever plan on getting anything to fit in the door openings....
i've clipped cabs and done general bodywork for years and i'm not trying to be a "hole",
but, would like to see you work in such a way that later on you don't bail on your project b/c of a lack of preparation or planning......:eek:[;)
BTW you can post pics here ya know.....
it's pretty easy level the body then two more cuts start with the center roof then the front then the rear doors are lined up tack and go!no biggie LATER BRADPS ALTERED FUEL COUPE
Are you gonna be able to climb in that pit?! Guess you only need to be in it for 10 seconds or so - right? :D
I say go for it.... since you already did. :)
