Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007!
Go Back   Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 11-10-2017, 03:56 AM
DozerII's Avatar
DozerII DozerII is offline
Thanks for all the great info and ideas everyone, triangulated it is.
Glen
Old 11-13-2017, 07:39 PM
Originally Posted by DozerII View Post
I'm not real comfortable with welding to the center section on the Chevy diff, but maybe the upper arms can be mounted just outboard of it?
Don't be afraid to weld on the center section. It's cast steel and should weld like a common mild steel. I have two recommendations, however...
- The cast piece is heavy and quite thick, depending where the brackets fall. A little preheat would help penetration. 150-200 F will suffice and a common temp-stick will tell you when to quit.
- If you plan to leave the bearings and axles in the housing during the procedure, place your ground clamp where the current and arc cannot pass through the bearings. (Don't clip your ground clamp to a wheel stud or axle flange.)
Dump the fluid, of course.
Old 11-13-2017, 08:34 PM
BillM's Avatar
BillM BillM is offline
Twice now I've used WelderSeries Triangulated kit - inexpensive, well made and Canadian to boot. (should make shipping a little easier)
I've used many of their products - and always been impressed with their stuff and support.
Old 11-14-2017, 03:21 AM
DozerII's Avatar
Thanks Doc, once I get the kit and frame shortened I can figure out where the brackets will have to be welded.
Thanks Bill I will check them out.
Glen
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
