thom
I'm working on our '41 Pontiac sedan again.
The plan is to install my 250 Chevy six with an automatic trans. I will rebuild the front brakes and change out the rear end for a newer, higher geared one. The stock bolt pattern is 5x5 so a late full size GM or 1/2 ton truck should work well.
The body is pretty solid but I will have some floor repairs to do. I want to run the stock wheels, hubcaps, and trim rings. Maybe some wide whites.
