Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Old 07-08-2018, 08:11 PM
kenny c kenny c is offline
If you are using parallel leaf springs in the rear a 90 degree setup may work better. If using a triangulated 4 link it may also help if you need a cross member to attach the upper links to. I like the 45 degree setup for looks and I feel it is a little stronger because of the longer joint but probably doesn't make much difference.
Tetanus Tornado 49 F6
