Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Undead Sleds... makin' old tin Undead every day! > Rat Rod & Hot Rod Talk
Old 07-11-2018, 08:48 AM
Blue Eyed Devil's Avatar
Devil's Advocate
Originally Posted by BlueNorther View Post
I have a feeling whoever built this has absolutely no idea how almost anything automotive works, or he wouldn't have installed the fuel tank backwards.
with the fuel outlets facing forward, the gas will slosh away from the fuel outlets every time you hit the throttle. of course on this rig that might be a "safety feature"???
The farther fuel stays away from that thing the better...
Old 07-11-2018, 09:57 AM
lowbudget50's Avatar
I changed the tank on a 70 mercury cougar and the factory outlet is in the front
Minterfab.com
Old 07-11-2018, 10:35 AM
Devil's Advocate
That's different from a sump-type fuel cell. They are specifically designed to be rear-facing.
Old 07-11-2018, 01:32 PM
I didnt pay attention that it had a fuel cell
Minterfab.com
Old 07-11-2018, 02:29 PM
05snopro440's Avatar
I was more interested in that fancy fuel line going to the front that has 3 clamps where it transitions to rubber. Cool. Totally missed that the sump was on the front.
To be fair, with that suspension being essentially solid I don't think it matters where the sump is. The fuel is going to be everywhere.
My '46 GMC on Photobucket
Old 07-11-2018, 09:25 PM
kenny c kenny c is offline
The rear end would move up and down if one upper link was removed. 1/2 ton Chevy pickups were set up this way with truck arms under the rear end and running forward. the coil overs would get softer instead of stiffer as they are compressed.
Tetanus Tornado 49 F6
Old 07-11-2018, 10:04 PM
Oh,So now we are applying common sense to this POS!
Old 07-12-2018, 06:02 AM
smallfoot's Avatar
Well, you know how these guys are...take a crumbling pile of caca and the next thing ya know he's riding around in a working, running, car or truck...
Fixing a little problem like that is a breeze, most would start with a torch or cut off wheel...
Old 07-12-2018, 09:00 AM
Bamamav's Avatar
Bamamav Bamamav is offline
I believe kenny is right, it's a truck arm style with an extra panhard bar. With two bars it will push the frame rails apart when it cycles. Take one off and it will allow the axle to shift sideways a bit when it cycles just like a 60's Chevy truck. A poor try for a Watts style linkage.
They should have used a cut off wheel. ...on the bed! Needs about 2' cut off to make it a short bed.
Old 07-12-2018, 11:01 AM
Only 9.5", that's all mine took to make it into a better looking shortbed!
