Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Engine Q&A!
Engine Q&A! The spot for engine talk, Q&A & tall tales!
Old 08-11-2020, 03:55 PM
Default What size overflow are you using?
Wondering if a 32oz overflow tank would work for my Nailhead? What ya thinks?!?
Old 08-11-2020, 07:20 PM
Skip's Avatar
Skip Skip is offline
I'm going to use a 2-litre Patron Silver bottle, if I can make a bracket that will hold it safely.
39 Ford PU Build. http://ratrodsrule.com/forum/showthread.php?t=36459
1928 Ford Tudor Build http://ratrodsrule.com/forum/showthread.php?p=538231#post538231
Old 08-12-2020, 05:39 AM
I was using a Even Williams 5th whiskey bottle on my 37 till the label came off so, I put a Corona bottle on and never had an overflow issue with either.
Old 08-12-2020, 05:41 AM
lazarat's Avatar
lazarat lazarat is offline
I have a 1 litre "V8 Splash" (tropical blend) juice bottle in mine. Gets a lot of finger points and laffs at car meets.
Level doesn't change much, car runs at about 185. But it does scrunch down a little when it does thirst. Might get something stronger.
Old 08-12-2020, 06:36 AM
DozerII's Avatar
DozerII DozerII is offline
I used a small boat fire extinguisher about a liter on the Essex, never over flowed on me.
Glen
Old 08-12-2020, 07:46 AM
If you overflow your overflow, you've got bigger problems!
