Old 05-28-2013, 09:10 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Default wiring
0H joysville, wiring
got some wiring done and mocked in the dash.
l figured the fuse box just inside the passenger side tucked up by the heater box is easy to get to & still out of the way.
not sure what year of 1940's Mopar l pulled this heater out of.
l ended up using the black heater, nice thing is it bolts in the same place and it has defroster vents in the right place and the other didn't have them where they would work, 0H WEll, l'll stick it in something someday, not like l won't have another project.
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 05-29-2013, 08:40 PM
skull's Avatar
Talking progress
headlights on to stay, grill shell & grille on, more wiring.
help is coming this week-end--goal: VR00M
looks wicked from straight on.
1930 2dr mopar.
Old 05-29-2013, 09:11 PM
You're getting a lot done on a little amount of time. It does look real good from the front.
Old 05-30-2013, 04:23 AM
ronnysplymouth's Avatar
ronnysplymouth ronnysplymouth is offline
Pretty bad ass Jim
Old 05-30-2013, 07:35 PM
skull's Avatar
Default tail
got the tail lights, 39 ford teardrops with blue dots
overflow surge tank hooked up, should work fine.
looking foreward to the week -end, lots of help so a lot should get done
Later
1930 2dr mopar.
Old 05-30-2013, 08:19 PM
Bamamav's Avatar
Bamamav Bamamav is offline
Better slip some tires on the front there Skull. All that HP is liable to collapse those jack stands!
Old 05-30-2013, 08:57 PM
ratchet041's Avatar
ratchet041 ratchet041 is offline
Lookin good
throw enough bad ideas together and it'll sound like a good idea at the time? And of course, add beer as necessary. ( quote by sam fear )
Old 06-02-2013, 01:05 AM
skull's Avatar
Default no VR00M
no VR00M but fire out the headers so it's got lots of spark. bonus it turns over with the key, so no jumping across the solenoid to get to try and start. we gotta play with the timing but almost 11PM so time to call it a night.
something l did not know, ford 9 INCH truck rear-ends takes a axle shaft almost a 1/8 of an inch bigger around than most car ones, l thought a nine was a nine.
we put in the 3.5O,s l pulled out of a 1967 truck, figuring 3rd member and the axles were the same, 0H well, live and learn, 2 hours putting it in & taking it back out.
the yoke on the 3.OO,s that was in the chassis was egg shaped. we just ended up fixing it by removing the egg shaped yoke and changing it out with a new one and resetting the tolerances.
trans line/cooler in, lines not as purty as D R's, but functional.
stuck a tire on to see how they fit, don't look too bad either.
Later
1930 2dr mopar.
Old 06-02-2013, 08:01 AM
Dirtyrat's Avatar
Dirtyrat Dirtyrat is offline
Got Fins?
Those lines look great, what are you talking about?
You are moving right along!
Rich - AKA DirtyRat
'12 VW Jetta TDI DSG
Build: '49 Ford F1 + '57 Pontiac, Liquid Propane Injected
1st start up on propane
1st real drive
Old 06-02-2013, 10:34 AM
Yep the ford truck nine inch is a 31 spline 5 on 5 lug pattern and the car nine is a 28 spline 4 1/2 on 4/12 lug pattern.
Hate it when that happens
