Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice  since 2007!
Go Back   Rat Rods Rule - Rat Rods, Hot Rods, Bikes, Photos, Builds, Tech, Talk & Advice since 2007! > Electrical Q&A!
Electrical Q&A! Electrical Q&A.. The shocking truth, tips, tricks & more!
Old 04-09-2017, 09:07 PM
53 stickfigure's Avatar
53 stickfigure 53 stickfigure is offline
Default 6 volt to 12 volt step up converter
I'm wanting a tachometer in my 53 chevy but the car is 6 volt. It was mentioned before to use a step up converter. I've found a few cheap ones on ebay and was about to order one but i noticed they have different amps. One is 6 volt in and 12 volt out with 1 amp and another is 2 amp. Does anyone know how many amps it takes to run the tachometer? I'm not worried about the light, just the actual tachometer itself. I've looked everywhere on the Internet and can't find anything.
Old 04-09-2017, 09:41 PM
First off make sure the tach is compatible with a V8 or 6 cylinder engine.
The tach doesn't pull any amps to speak of.
1933 Pontiac 401 GS Nailhead
1935 Dodge pickup Blown Big Block
38 Ford Bobber
1948 GMC 5 window
51 Chevy 5 Window
Peabody's 37 GMC
It takes someone getting close to use a knife on you......... "Torchie 2016"
Old 04-10-2017, 01:38 PM
edeee2 edeee2 is offline
Default not sure
but I think I seen a 6 volt tach in speedway book
Old 04-11-2017, 08:07 AM
Blue Eyed Devil's Avatar
Devil's Advocate
WesTach can build you a 6V tach. - http://www.westach.com/
But really, why not just convert to 12V? It's way easier (and cheaper) than jumping through all these hoops to make an antiquated charging system work. Obviously not a restoration here, and there is a reason 12V became standard. Do the conversion and run any tach you want.
Old 04-11-2017, 06:41 PM
Im gonna run the 6 volt this summer then put her in the garage this winter when im not driving her to change a lot of things over. This is just a for now thing.
Old 04-12-2017, 08:23 AM
Devil's Advocate
The 12V upgrade can literally be done in a few hours, not hard by any means. Here's a good How-To -
http://www.how-to-build-hotrods.com/6v-to-12v.html
Old 04-12-2017, 09:08 AM
Thanks BED I've been looking for the part numbers for the balance resisters.
38 Ford Bobber
1948 GMC 5 window
51 Chevy 5 Window
Peabody's 37 GMC
Old 04-12-2017, 10:11 AM
Devil's Advocate
Glad to be of service...
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
