Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Transmission, Rear End... Talk & Q&A!
Old 01-13-2018, 11:01 PM
23crate's Avatar
23crate 23crate is offline
Default LA 318 & 904 trans
HI ...
any thoughts on a more economic option ?
was chatting to a buddy of mine last nite was claiming around $37.75 of gas to do 344 miles ~ ive worked this out to US dollars ~
hes running a 327 / 700r4 in a twin spinner so theres a little weight
we pay $8.01 for a gallon ( yes I know raped then robbed for gas !!)
SO then after all that .. what if any is a good gas mileage trans for a LA series 318 ?
thanks
Crate
duct tape can't fix stupid, but it can muffle the sound.
the greatest victory is to live
Old 01-14-2018, 12:11 AM
Bamamav's Avatar
Bamamav Bamamav is offline
Maybe add a Gear vendors OD behind the 904?
Old 01-14-2018, 06:58 AM
DozerII's Avatar
DozerII DozerII is offline
A A518 overdrive from an 89-92 Dodge 2wd dakota, durango or full size van, the later ones are electronic and need a computer to run them.
Glen
Old 01-14-2018, 02:12 PM
Dr Crankenstein Dr Crankenstein is online now
Every engine has its "sweet spot", where a few hundred RPM can be the difference between poor mileage and good.
At cruising speed, you want your motor to be its powerband, unless it's a very light car. For example: If the 318 doesn't make torque until 2200 RPM, don't ask it to spin 1800 and deliver mileage.
Obviously, an automatic OD has its advantages. Most have a lower 1st gear and naturally, an overdriven 4th. You need a properly matched diff ratio and tire size to benefit from any transmission's ratios.
I would find the 318's specs and the ratios for your transmission candidates... plug all your numbers into a calculator.
https://www.ringpinion.com/calculators/Calc_RPM.aspx
Old 01-15-2018, 03:48 AM
23crate's Avatar
Thumbs up
Thanks Dr C theres abit to think about there.. I guess there any cam work, head flow work , can alter torque to factored into that
for some reason I was working on some generic application, but is not quite as easy ..
dam good start that link !!
Bama had a look at the Gear vendors site .. poss a bit pricey at this stage ~ but its early days in my build. so come to that ..
or even look at the A518 ..
before all that I get my sh#t sorted..
Thanks All
Old 01-15-2018, 09:59 AM
I'm all for the A518
I'm gonna put one of these behind the 392 Hemi I'm putting in the 37 GMC
Old 01-15-2018, 11:19 AM
DozerII's Avatar
And I'm putting one behind the 440 in my 28 FastFour
Glen
