Old 08-02-2018, 01:44 AM
dutch dutch is offline
sweet! congrats
Old 08-02-2018, 12:01 PM
MercuryMac's Avatar
MercuryMac MercuryMac is offline
Builder Junky!
When your car gets an outside day AND gets to run up and down the driveway, You're well on your way. Congratulations!
Old 08-02-2018, 12:21 PM
Abasham Abasham is offline
Congrats! I canít wait for that day
Old 08-02-2018, 12:49 PM
CORPO's Avatar
CORPO CORPO is offline
Buildin' it his way, one piece at a time...
Congrats man.. Turned out great
My Build 1936 Low Cab 1.5 ton
http://www.ratrodsrule.com/forum/showthread.php?t=9479
Old 08-03-2018, 11:18 AM
BillM's Avatar
BillM BillM is offline
Default Thanks
Thanks everyone. It sure feels good - a bit nerve racking but it's good. I'm still debugging things, but it's starting better, and running a little better. I've not having much luck getting these carbs setup just right - seems that as soon as I connect the vacuum line on the secondaries, they open slightly and the rpm shoots up to 3k or so. I'll mess around and get things right yet.
It was too muggy to be working any more today, so we lined them up for a quick photo op. My uncle had his '29 out today, so we took these
Old 08-03-2018, 12:10 PM
good lookin pair
The vacuum pots work off venturi vacuum and not manifold vacuum
Old 08-03-2018, 02:39 PM
BillM's Avatar
Thanks Old Iron - as I research more, I see that the pots are venturi vacuum operated. I'm confused by my pots though, as they have a port on the top - which is what I connected to the base of the carb, and that's what sent my RPM high. I can't find any information on what I have, and where they should be connected. Do you know?
File Type: jpg thumbnail_20180803_142503_resized_1.jpg (104.6 KB, 29 views)
Old 08-03-2018, 06:06 PM
Old Iron must be busy with something, so I'll stick my fat nose in...
You don't provide or draw vacuum from the vacuum pots. (Like Old Iron said, they source their vacuum "internally" through the body of the carb.)
The barbs on your pots should be connected to each other. They're meant to equalize the vacuum signal between the two pots, so the secondaries will synchronize and act in unison...
Old 08-03-2018, 06:24 PM
BillM's Avatar
Thanks Doc! My stupid mistake.....they were hooked up that way and I figured that was wrong....put it back and it's better. I do have an issue with the accelerator pump on the back carb - I think that's my primary problem right now. I'll rebuild and update!
Old 08-03-2018, 06:49 PM
Please do. Holley Brothers unite!
