Go Back   Undead Sleds / Rat Rods Rule - Hot Rods, Rat Rods, Sleepers, Beaters & Bikes... since 2007! > Fuel systems Q&A
Fuel systems Q&A Carbs, injection, tanks, lines, pumps, everything fuel system related!
Old 05-12-2019, 01:00 PM
skull's Avatar
skull skull is offline
Lightbulb like
it should not make much of a difference if the intake is a dual plane, fuel still goes thru the manifold pretty much in the same way with the spacer moving the carb up, l think it looks cool with the spacer.
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 05-13-2019, 10:44 AM
05snopro440's Avatar
We usually use a 1/2" or 1" phenolic spacer under a heat shield to reduce heat transfer to the carb, then put the carb on top. I don't think that 2" spacer will help drivability but it might not make a big noticeable difference.
My '46 GMC on Photobucket
Old 05-13-2019, 09:30 PM
sgtpontiac's Avatar
sgtpontiac sgtpontiac is offline
Older, Wiser and Still Buildin'
See.... It's true.... Size doesn't matter...
My 96 GMC Rat Buildbuildthread
Old 05-28-2019, 10:27 PM
if it is a 4 hole spacer, you might gain a few lbs-ft of low end torque, if it is 1 big square hole it will kill a s___t load of low rpm torque but may give you a little higher top rpm.
the only reason to run a 2" 1 hole spacer is if you are class restricted to a very small cfm carb, the big open plenum will act as a reservoir of fuel mixture so there is less restriction for each cylinder to draw from. this is why you don't see them on the street.
