Old 05-29-2010, 03:37 PM
Default 34 Ford 5 Window Coupe Hot Rod
I'm going to start a thread for the 34 5 window. This is more of a rebuild and finish thread. Al ittle history on the car. It was purchased be the last owner in 1958 for $10. He had started working on the car and had completed a lot of work on it. Unfortunately he passed away last year and never completed it. I found out about it through a friend of mine who knew them and was able to purchase it from his widow.
It has quite a few new parts on it like the fenders, running boards, the associated braces, fuel tank, winshield frame and lots of little parts.
The original engine was replaced with a 1936 engine which has the insert bearings instead of the babbited main bearings. The brakes have been converted over to hydraulics and tube shocks on the front axle.
It was paint in the early 60's and the upholstery was started in the 70s.
Here's what it looked like when I first found it.
And this is what it looks like now after a good cleaning and buffing.
The paint on the back in flaking off but it will stay that way. It adds to it's character.
Old 05-29-2010, 03:51 PM
I did start working on correcting a few things on it this week.
The front spring was sagging and the shackles were hitting the axle.
I got a Posie's Super Slide front spring to replace the old one. It has reversed eyes and fewer leafs. It should lower it by about 2" in the front.
Axle and spring are in a much better relationship now.
However, when removing the old spring I stripped out one of the u-bolts and I noticed shackes and bushings were pretty worn and need repalced. Parts are on order.
Old 05-29-2010, 04:05 PM
I was checking the wheel bearing and brakes on the car and on the drivers side it was missing the shoe return spring and the grease cover. I had a grease cover so I installed that. I thought I saw the spring in all the extra parts I got with it but I'm still looking for it.
The shocks were put in upside down with the dust cover facing up so it would catch water.
So I cut the cover off and discovered that the shocks are too long and bottom out with all the weight on them. So they will need to be replaced with a shorter shock.
It also has a bent tie rod.
Old 05-29-2010, 04:09 PM
I installed the rear bumper and licence plate bracket.
And got some new scoops for the new flathead. These will have small air cleaners inside.
Old 05-29-2010, 05:11 PM
Shea Laking's Avatar
Shea Laking Shea Laking is offline
Mmmm.....YUMMY!! Thanks for sharing your pics!
Regards,
Shea
"Just cause you could doesn't mean you should"-Davidhud29
Father,School Bus Mechanic, Home Handyman, Car Lover, Husband-All to varying degrees of mediocrity
Old 05-29-2010, 06:42 PM
Dave50's Avatar
Dave50 Dave50 is offline
Very nice Dm
Old 05-29-2010, 07:35 PM
DMW, i really think that this old 34 is far too gone to salvage and would be willing to come out there and get it outta your shop before you put anymore money into it...........[ddev[ddev
i'm sorry, that just came out--i know a preacher shouldn't be this cantankerous but this car is oh-so-cool to borrow a phrase from PA41 i think this car has soul
and i'm glad to see someone got it that appreciates it as much as i feel that you do......
Old 05-29-2010, 08:13 PM
Todd's Avatar
Todd Todd is offline
He's just one of them Rusty-Chainers!
That was a visual treat, thanks for sharing.
Old 05-29-2010, 09:05 PM
LarryH's Avatar
LarryH LarryH is offline
That thing is so cool. All it needs to be perfect is...uhhh...well...lemme see...i got it...sitting in my driveway.
Old 05-29-2010, 09:15 PM
Sweeet! I can forsee you getting a lot of satifaction from owning this old car Don.
