Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 08-02-2010, 12:04 AM
mikes686 mikes686 is offline
Default quartet elliptic springs up front
i am wondering about running quarter elliptic springs up front on my 46 dodge 1/2 ton. she has parallel springs right now and i am curious if anyone else has done this to set the front end out in front of the engine. it probably would be a kind of suicide front end but with q.e. springs instead of a transverse set up.
rust is easy to color match
Big Mike
Old 09-15-2010, 11:38 AM
DaddyT DaddyT is offline
It really wouldn't be "kind of a suicide front end" just a stretched out wheel base and in my opinion probably a safer one. You'll have two mounting points from the frame to the axle vs. a transverse set-up which only has one. If one should fail the other will help support your ride until you come to a stop. Plus it looks cool too. It may be difficult to locate shocks from your frame to the axle depending how long you extend the front end and how nice you want it to look.
Old 09-15-2010, 04:36 PM
BloodSweat&Whiskey BloodSweat&Whiskey is offline
My truck is setup with 4 quarter eliptical springs up front. I would still call it a suicide front end. Simple fact is if there is a failure you are going for a ride just like any suicde front end. I do not run shocks and mine travels fine down the road. I have to be on a really bad road to tell.
BSW
Old 11-22-2011, 06:34 AM
phillip-r-s's Avatar
phillip-r-s phillip-r-s is offline
I just wanted to bump this one up front again. Any more pics of q-e front ends out there. Thanks all, just preparing for thursday. I am thankful for each and everyone of you. Even torchman
Old 11-23-2011, 11:10 AM
boostedcleveland boostedcleveland is offline
curious. do you still have to run trailing arms or the spring location settle that issue. just run a panhard bar. i have a mono leaf setup off a drag car wondering if that would work
Old 11-26-2011, 10:49 AM
do you still have to run trailing arms on the front
Old 11-26-2011, 04:44 PM
King Herald King Herald is offline
No, the springs are the trailing arms, the are like a four bar set-up in reality.
No need for a Panhard rod either, as your springs take care of any sideways loading, if they are mounted well.
They laugh at me because I am different.
I laugh at them because they are all the same.
Old 03-03-2012, 01:00 PM
meteorman's Avatar
meteorman meteorman is offline
Default brake lines?
I'm running a quarter elliptic setup and getting ready to run my brake lines.
How did you run the brake lines on your rig BSW??
Do you have really long flexible hoses?
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
