Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 10-17-2010, 07:32 PM
blacksheep's Avatar
blacksheep blacksheep is offline
Default Help with front axle set up.
Ok, my ol 48 Ford is stock paralell springs in the front right now. I am wanting to lower the front by going to a single spring set up. Can I just use one side and turn it 90* with newly built brackets? Also , will I run into issues with steering arm that runs to the passenger side ? This is the way it is set up right now. I am wanting to get rid of that extra two feet of frame that sticks out in front of my radiator.
Old 10-17-2010, 08:56 PM
On my grandson's '38 GMC (there's a build thread on RRR) we used one of the Ford F1 springs as a cross spring. Had to add about 4 leaves from the other spring. I doubled up on the leaf next to the main leaf and then went every other and doubled those. We built a dropped tie rod to clear all the stuff in the way.
Old 10-18-2010, 09:36 AM
hey man check out this build thread, it might give you an idea or two...
"next project" (by hotrod preacher) it is my 52 ford f-1 and i think you'll like how we did it...wish i knew how to make it a link for ya
Old 10-18-2010, 12:28 PM
blacksheep's Avatar
Well, I think I'm just gonna wait until my next build to change anything. This truck rides so good now, I hate to change it up at this point. I did notch the top of the frame and cut a pie shaped piece out of it, so I could lower it just about 2". I do like it much better now.
before
after
The reason it doesn't look like much , is because I also lowered the rear too by about1 1/2"
Old 10-18-2010, 12:52 PM
Unkl Ian's Avatar
Unkl Ian Unkl Ian is offline
Allergic to Idiots
Quarter Elliptics.
Much better than a transverse spring.
FlyingEyeballs.net
Old 10-18-2010, 01:51 PM
blacksheep's Avatar
Originally Posted by Unkl Ian View Post
Quarter Elliptics.
Got any photos of this set up. Looking for something different
Old 10-18-2010, 06:14 PM
blacksheep's Avatar
I've been doi9ng some reading on the quarter eliptic set up. I'm kind of diggin it. Any chance of me using my stock front springs for a projwect like this. Maybe a dumb question, but I just had to ask. Gotta save moolah where I can.
Old 11-13-2010, 02:35 AM
King Herald King Herald is offline
I used quarter elliptics on the front of my Morris. it was just some spring I found, cut in half and re-drilled a hole in each leaf for a lining up bolt.
I never had a decent camera at the time, so pics are a bit rubbish:
Upside down view of spring pad, engine mount is the other small tab:
Old 11-13-2010, 08:44 PM
moparcowboy's Avatar
moparcowboy moparcowboy is offline
Thanks King Herald for the pic. Did you cut the springs yourself? If so what did you cut them with. tried to cut some with band saw and it trashed the blade
Old 11-14-2010, 06:15 AM
I cut them with a 1mm blade in the 5" angle grinder. That is pretty much what I use for cutting anything, even tiny stuff. Too lazy to reach for the hacksaw nowadays.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
