Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007!
Go Back   Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Undead Sleds... makin' old tin Undead every day! > Rat Rod & Hot Rod Talk
Old 02-12-2011, 10:24 PM
rainman rainman is offline
Rough Rodder
Anybody know anything on this set up? I've never seen this one before and wonder the pro's and con's of it.
Thanks Bonehead!!
Old 02-13-2011, 07:16 AM
King Herald King Herald is offline
That setup looks like the chassis end is just a lightweight bolt on bracket, when it has to support the weight of the car, plus the torque of the axle under drive etc.
Mind you, it looks like the rest of the chassis is fairly light gauge steel too.
They laugh at me because I am different.
I laugh at them because they are all the same.
My RPU thread
My Healey Thread
Old 02-13-2011, 09:44 AM
Rough Rodder
Yeah I've got several questions about it too, it looks like the springs are very close to the frame rails. May just be the pic though. I like the concept though!!
Old 02-13-2011, 10:17 AM
R Pope R Pope is offline
That's a lot of twist on those little bolts! Looks like 3/8" bolts, maybe four of them in each stand? Pretty flimsy. But then, it isn't finished yet.
Old 02-13-2011, 11:25 AM
Dragfink's Avatar
Dragfink Dragfink is offline
My '39 Pontiac gasser, built in 1964, had quarter-elliptic suspension front and rear...here's a couple pics of the front suspenion...the rear also had 4' long lift bars...
Old 02-23-2011, 07:14 AM
Moparfinman Moparfinman is offline
Thanks for the input. Still have some research to do.
Old 02-23-2011, 07:08 PM
cosmic12's Avatar
cosmic12 cosmic12 is offline
I put them on the frt of my 37 Pontiac but I am only going to run a inline 6.
I haven't driven it yet and the pics are just a mock/tack up so far.
I just like how it looks.
Old 02-23-2011, 08:44 PM
My 'Glass '27 roadster has quarter elliptics and is the best riding hot rod I've got.
Old 02-26-2011, 01:13 AM
Blacksmith54's Avatar
Blacksmith54 Blacksmith54 is offline
Cool Quarter-Elliptic springs
Last year I helped my son build a fiberglass T-Bucket for a Senior Project at ASU as it had to be done in a timely manor he chose a simple car to build, him and his two class mates put in about 1500 hours during the design and build of the project. As a lot of the project was pulled from my stuff we used a lot of things that were different about how we did the car one notable thing was he chose to use Quarter-Elliptic springs both front and rear we used springs from a Suzuki Samurai (they are two inches wide) and as we were punting at the time as to the total weight (460. C-6, nine inch) we figured that the weight on the springs could be adjusted at a later date, The boys finished the car with about two weeks to spare (so they could concentrate on finals) the car was tested using accelerometers to check acceleration braking and lateral forces .88 accel .91 braking and .85 lateral (on seven cylinders,bad cam). During the design phase he learned a lot of people use quarter elliptic s as the lateral stability system IE instead of a panhard bar, springs are meant to do the work of springs and bend well up and down, not so good sideways. His car has Watts links both front and rear. My son also has a 2010 Mustang with a drag pac and the T-Bucket will out handle and out run it.
"When I die I want to be cremated, my ashes put in an envelope and mailed to the government, with a short letter saying...Now you've got everything."
Old 02-26-2011, 09:12 AM
ratrodz's Avatar
ratrodz ratrodz is offline
what kind of springs did you use.have any pics where it mounts to axle. love the setup real clean looking. thanks
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
