Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Product Reviews!
Product Reviews! Give your pals the thumbs up or thumbs down on products you've tried!
Old 03-22-2011, 03:15 AM
Motorhead's Avatar
Motorhead Motorhead is offline
Default Central Pneumatic Garage Air Kit (#66747)
I needed to plumb my shop for air, as I was tired of having a mess of air hoses all over the shop. I came across a a Central Pneumatic Garage Air Kit at my local Harbor Freight store (part number 66747) and decided to buy it. It's usually a $100 item, but it was on sale at $54.99 and I had a 20% off coupon. It ended up being about $47 out the door. It is very very similar to the Rapid Air kit that sells for three times the price. It comes with 100' of 1/2" O.D., 3/8" I.D. tubing and all the fittings in the pictures.
I had the quick connect. It wasn't included in the kit.
Well, I went ahead an installed it. It went together in a few hours. The biggest problem was uncoiling the hose, but I managed to get it done.
I put the kit together in a few hours, but I've spent the last three days trying to fix all the leaks. EVERY CONNECTION IN THIS KIT LEAKS! I got the leaks down to a "managable" amount, such that my 60 gallon tank would go from 130 psi down to about 30 psi in 24 hours. Well, today I went to use it and a quick connect fitting popped out and drained the tank in a couple of minutes. The slightest (and I mean SLIGHTEST) movement at a quick-connect fitting can fix or create a massive leak. This kit is the finickiest thing I've ever bought.
Harbor Freight has a lot of good stuff, but this kit is a total piece of crap! It is coming down tomorrow and it will go back to the store.
DON'T WASTE YOUR MONEY. STAY AWAY!!
I SOLD MY SOUL
FOR ROCK 'N' ROLL
1941 Dodge Truck - Project
Old 03-22-2011, 08:55 AM
ratrodz's Avatar
ratrodz ratrodz is offline
i used pvc pipe in my shop 12 years ago no leaks easy to install no problems so far
Old 03-22-2011, 09:12 AM
Charley Davidson Charley Davidson is offline
Thanks for the heads up, that's one hell of a nice shop you got there.
Old 03-22-2011, 09:15 AM
donsrods's Avatar
donsrods donsrods is offline
When we did our shop we had read so much about pvc tubing having problems that we went with galvanized pipe instead. There have been cases of the pvc exploding and sending shrapnel flying clear across the garage, and in some cases injuring someone.
I know there will be people on both sides of the debate on this one, but we just weren't taking that chance.
Old 03-22-2011, 10:24 AM
I used 1/2 inch pipe, years ago, and it still works great.
Old 03-22-2011, 10:29 AM
darkk's Avatar
darkk darkk is offline
Use PEX tubing (water or heating) works great and you can get it in 1/2"-1 1/4". I used crimp fittings, but there are sharkbite press fitting that actually work very well. Much better than some of the plastic line air kits I've seen.
DD 2007 VW Jetta 5 cyl w/C2 stg2 Turbo Kit
1946 Hudson Pro Street BBC
1999 HD stg 4 95" Road King Customized
750 HP 388" Chevy stroker just looking for a new rod to motivate...
Old 03-27-2011, 03:47 PM
hotrodbill hotrodbill is offline
I was really considering one of those kits....thanks for the heads up.
I think I'll just use pipe.
I just have a 2 car garage, but I want air at all the walls, the roll up doors, and a couple outside.
Old 03-27-2011, 08:14 PM
blacksheep's Avatar
blacksheep blacksheep is offline
I use soldered copper pipe in my shop. I also put a moisture P type trap every 15' or so. I can go to any point and drain any moisture out of it. But, I now have driers. Commercial shop should not use PVC. Home shop it will last forever, and as long as you don't get over 139 psi you are good to go.
Old 03-28-2011, 09:12 PM
sgtpontiac's Avatar
sgtpontiac sgtpontiac is offline
Older, Wiser and Still Buildin'
Default I was also looking at the HF air kit
I will move from that idea quickly..... always wondered about pvc.. stayed away from it from all the supposed horror stories.... Never thought about PEX.... any other thoughts about the use of PVC or PEX? The temp changes between when I'm in or out of the barn, (heated then cold) will that have a factor?? Just wondering...... I think my compressors are set at 130psi both of them.....
My 96 GMC Rat Buildbuildthread
Old 03-28-2011, 09:24 PM
EnglishBob's Avatar
EnglishBob EnglishBob is offline
Have a similar kit in my shop for a couple of years and even through our winters it's held up fine.
