Old 03-25-2011, 06:49 AM
Tim...Ok's Avatar
Tim...Ok Tim...Ok is offline
Default Tim...Ok's 48 F1 build
Well, I think it's finally time to start a build thread..I've flip flopped so many times on what i want to build, but for now I'm planning on going forward with the 48 F1 cab,subject to change the chassis was actually started with intentions of a hand built sedan body, but plans change..anyway
tapered front rails to give them some shape..I rolled the tubing for my radius rods and machined the bungs at work
brackets I had laser cut
front perch and trailer spring
still on the table..grill shell made from pie cut angle iron..looks more model T'ish than i wanted,not going to use it..Will make a wall hanging stereo shelf out of it
the front half now has tires and wheels and is sitting on the ground..thats a good milestone for someone who doesn't know what the heck they are doing
Old 03-25-2011, 07:01 AM
Tim...Ok's Avatar
I guess I should say this is the first time I've built anything like this..I've done the back halves on a couple drag cars , but never built from scratch and never owned anything with a solid front axle..I have done alot of welding on industrial type platforms and shelving..Built quite a few trailers and flatbeds,that sort of stuff..I use a Miller 250X that I've had for about 12 years..
Heres a 20' Gooseneck I built
a motorcycle trailer I built for a co-worker, traded it to him for a clean 81 SWB Chevy truck
and my eternal project, my 18' tilt deck car hauler..I seem to redesign it about once a year
Tim
Old 03-25-2011, 12:09 PM
Hey, you haven't been snooping around in my build thread have you
Looks like you're off to a great start! I'll be watching the F-1 build and the stereo shelf
Old 03-25-2011, 12:25 PM
Tim...Ok's Avatar
I wanted to give credit where due for that idea, but I 've read so many posts on here, I couldn't remember who had done that..Thanks for the idea!
Love your Willy's btw
Old 03-25-2011, 01:34 PM
Nice work, both of you.
Old 03-25-2011, 05:37 PM
blacksheep's Avatar
blacksheep blacksheep is offline
Hey man, nice start there. You could do what I did, and build your front grill from two full size Chevy truck door window frames.
Old 03-25-2011, 10:48 PM
lvin4jc's Avatar
lvin4jc lvin4jc is offline
That's ingenious! Good eye figuring out that would work out so well.
Current - 1969 Ford F100 351W swap / 4spd Stick 2wd "Remmy" the Rat Rod
Gone but not forgotten -
1951 F1
1963 GMC
1962 F100
Old 03-25-2011, 10:58 PM
38fordtruck's Avatar
38fordtruck 38fordtruck is offline
looks like a great start
cardomain page
build thread
Originally Posted by GJunktionMike View Post
See you rattle his tree and he falls out and gets back to work
Old 03-26-2011, 07:31 AM
Tim...Ok's Avatar
Blacksheep, that worked out better than i would have ever guessed,too cool..A side view of your truck is among the pictures I have as a screen saver on my computer..
thanks guys
Old 04-09-2011, 07:55 AM
Tim...Ok's Avatar
I've made a little progress the last few days but didn't take any pics..I finished the bungs in the ends of my front bars,got the heims in and installed..so the front is a roller..Was excited to see that it turns lock to lock without binding and clears everything nicely..remember,first build here I'm trying to find an early truck 9" rear then I can finish the roller.. I found a steering box that I'm hoping will work,I'll post pics of that once I get it off of the donor..
Tim
