Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007!
Go Back   Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Frame/Suspension/Brake... Talk & Q&A
Frame/Suspension/Brake... Talk & Q&A All things... Frame/Suspension/Brake
Old 04-22-2011, 01:28 PM
CORPO's Avatar
CORPO CORPO is offline
Buildin' it his way, one piece at a time...
Default Lever arm shocks (hydraulic)
I know I have heard that the friction style ones don't work all that well... But what about the hydraulic lever arm shocks...? Anyone have some input, I am just wondering how they perform in compaired to modern tube shocks. I like the way they look and I think I would have a less intrusive way to mount them on my front end compaired to a tube shock...
Thanks guys
My Build 1936 Low Cab 1.5 ton
http://www.ratrodsrule.com/forum/showthread.php?t=9479
Old 04-22-2011, 07:28 PM
Most of the old car lever shocks are single action. They only control rebound (or is it compression??? I can't remember). I have used British lever shocks on the front of light hot rods. They look and work good. Frequently found on eBay.
I have home made friction shocks on my '27 roadster. They don't do a lot but they are all that is needed on it.
Old 04-23-2011, 11:18 PM
old28's Avatar
old28 old28 is offline
I used some Delco Lever Action Hydrolic shocks on the rear of my 29 RPU and they worked out real nice with the 40 Ford leaf rear spring. I think they look right on this build and I don't think regular shocks on the rear would have made it any better.
Up front I used regular tube short shocks from Speedway Motors as I had a space concern to work with. I still might redo the front to put in a small Delco that I think was on early Chevy cars or truck.
I think a lot of the choice is in the "LOOK", They just look right on old hot rods.
Old 04-23-2011, 11:46 PM
zzrodder's Avatar
zzrodder zzrodder is offline
Some of the lever shocks like those on my 34 Caddy had adjustable damping, here's a pic - though wearing 77 years worth of crud, they still function. It had a lever under the dash and a series of rods etc. linked to all 4 to adjust while driving. There was an article in one of the rod mags a year or so ago about the various Ford style lever shocks and there was a company that rebuilt them. Sometimes they fit better into tight places than tube shocks and definitely have that period look.
Old 04-24-2011, 10:07 AM
CORPO's Avatar
Do any of them have dual action, or were they all single action? I am looking at some from a 40's 3/4 ton chevy that I thought would work well, but I think I need resistance in both compression and rebound.
thanks guys
Old 04-24-2011, 11:10 AM
rustybeercan's Avatar
rustybeercan rustybeercan is offline
Never met a beer he didn't like!
There was an article on rebuilding them a few months ago in one of the big car mags. You can probably find it with the Goog.
Beercan
Professional beer can emptier and recycler!
Old 04-24-2011, 12:35 PM
Very nice rear shock set up, old28. The ones he used look like double action.
Chevy trucks got by with single action shocks for years so they might work ok if you have pretty stiff springs on your ride.
Old 04-24-2011, 06:02 PM
old28's Avatar
CORPO
The Delco I have on the rear are double action, but they are way stiffer on compression than on rebound. They are fine on light hot rods with stiff springs like (bob w) said.
If your doing a heavy rod I don't think you would be happy with the overall performance they would provide.
If you find some good double action that came off a vintage 3/4 ton they might work out fine for a heavy hot rod. This may be a case were "the right look" may have to take second place.
Good Luck
Old 04-24-2011, 08:19 PM
CORPO's Avatar
hummmm... so how do I know which ones are double action? I was looking at something like these????
any input would be helpful.. and I dont think I would consider my truck light...
http://cgi.ebay.com/ebaymotors/ws/eB...NA%3AUS%3A1123
Old 04-24-2011, 08:42 PM
If you are looking at a functional shock the lever will have very little resistance in one direction.
http://cgi.ebay.com/ebaymotors/Austi...item4152b120bf
Here's a British double action shock. you can see two distinct cylinders. Look at old28's shocks and you can see two cylinders that are opposed. I think (but am not positive) that all double action shocks will have two cylinders either side by side, like the British shock or opposed, like old28's shocks.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
