On dolly at home
2007-07-10
Before I could bring it home I had to make something to put the body on so it’s movable too. I didn’t want it sitting ‘dead’ on the ground, unable to be moved. I took some spare angle-iron I got from my father-in-law. The angle-iron once was part of a palisade fence. I quickly put this dolly frame together for the ’34. After these photos were taken I actually added castor wheels to enable me to easily move it around.
In the first pic, to the right, you can see the end of my 6m deep by 16m long carport I built in the back-yard. The roof has since been completed too and the body is now safely under it. In the last pic you can get a better idea of where the bottom of the tail end was damaged.
I have already got quite a few of the major component for the car like an early 70’s 350 Chev V8 with TH350 ‘box, a 1956 Chev 10-bolt rear end, 1938 Ford front suspension and even the steel tubing for the chassis.
The Ford front suspension won’t be used as is though. The transverse spring will be moved behind the I-beam axle, the wishbone will be split and the Ford drums will make way for Chev discs. This suspension will then be mounted in a suicide style, very similar to what is done on T-buckets.
