Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
![]() I started with a 400 buck Ebay buy. A 1940 Studebaker Commander 4 door sedan. ![]() I was thinking about parting it out and use the money for another project, then I put it out for possible trade, but no interesting options happened, so I figured what the hell... and cut the front suspension off the stock frame (it had what they called a "planer" suspension...one of the first independent front ends, but not what I wanted for reliablity and safety) Here's the stock suspension before my brother in law and I started cutting ![]() and here it is afterwards ![]() Yeah, I'm sure some of you are looking and thinking to yourselves I must be an idiot for cutting it apart on a dirt driveway, but as primative as it looks we actually had everything squared up and braced before we started cutting. We also had taken a bunch of measurements and had a factory service manual with factory dimensions for reference. Believe it or not when we got it rolled inside on the level floor (after it was cleaned out to make room for the car) we double checked all of our measurements and everything was right where it should be... the worst any measurement was out was less then 1/8 of an inch. Once the stock stuff was out of the way, I rolled an S-10 front sub frame under it that I had laying around. A Camaro or Nova sub probably would have worked better, but the S-10 unit was what I had at hand and it had a factory disc brake set up I wanted. As a side note...the front of the S-10 fram has these ugly looking brackets for the factory bumper to mount to....they got cut off and when I needed front spring mounts for the rear end...they got recycled. They actually worked out pretty good for the front spring pockets and fit up in the factory frame where we could weld them up good and solid. ![]() Once everything was measured and trimmed (and we figured out how to make the two come together the best way) we tacked the sub to stock frame and started the bracing tying the two together. The S-10 sub has a formed flange on the drivers side that points inboard, where the transmission crossmember bolts to. This worked out to our advantage. We measured the thickness of the flange and cut the stock frame so that the flange would slide into the stock frame. Also, we were able to slide a 2x3 tube into the factory frame on both sides and they helped support the S-10 sub from underneath. I have some good shots of the way everything fit together and how we welded everything up as it was going together...BUT they are on the hard drive of my other computer and I didn't get them up loaded before the motherboard took a crap. Once I get another mother board I'll get them up loaded to my photobucket account where I'm trying to keep all of the pics so they are available. Anyway, I'll start typing on the next post so I can include some more pics of some of the stuff that's been done
Cool cars, hot women and cold beer...what else in life is there? 63 Nova build http://ratrodsrule.com/forum/showthread.php?t=28029 40 Studebaker build http://ratrodsrule.com/forum/showthread.php?t=2343 |
Ok some more pics...here is a close up of the initial S-10 / Studebaker mating
![]() Now you see why I said a Camaro sub might have worked better, because the S-10 is wider then the Camaro sub, but with the 2x4 tube and other bracing and welding done it's not going anywhere adn once everything is finished up and the car is back together you won't see where everything was tied together unless you get it on a lift. Here's a pic of where the S-10 flange I mentioned in the first post slide into the factory frame. Now underneath that is also the 2x3 tubing that was slid into the factory frame and welded up then this slid in on top of that and that was all welded up. I wish I could show better pictures but like I said they are safely hiding on my old hard drive until I can get them off of there ![]() Here is a shot of how the motor mounts were welded up to the S-10 frame..By the way did I fail to mention that this set up moves the motor back and down from where the motor would mount in an S-10? It really changes the center of gravity for the better on ride quality and handling. ![]() on the next post I'll show a couple of other pics, but not anything major...just some overall shots (what I could get in the garage)
Here is a side shot (sort of) of the car sitting in the garage.
![]() I still have to put lowering blocks in the rear (that's an S-10 unit also, but from a 4x4 since they are a little wider then the two wheel drive units) ![]() At this point, I have to do the tin work around the firewall and toe board area and fix a few spots in the factory floor. The plans are for a set of Benneville SSEi full power seats (for my old bones to be comfortable). I still have to wire it, but again being the cheap old bas....being cheap..I'm recycling the wire harness from an old Chevy pick up. Once the other things are done, I'm gonna do some sanding and some satin black will be the color of choice. As I get some of the other stuff done I'll post a few updates, and hopefully have a few shots of it out on the local roads before to much longer
Ron,
Lookin' good so far! Kool lookin' & unusual car... think u'll b glad u kept it!!! BoB
Rust... Mother Nature's paint job... don't fool with Mother Nature! RRR on Facebook RRR on Twitter Wanted: Ratty '35 Olds coupe! |
Ron,Its something that is different.The build looks like its coming together as you wanted it.
1929 Pontiac George I wish I could remember everything that I have already forgotten....... |
$400.. Very Nice
Ron, any progress on the 40?
dmw...Livin' on Route 66 ![]() "No matter how smart you are you can never convince someone stupid that they are stupid." 34 Ford Coupe 51 Ford F1 50 Stude Champ Intro |
I've gotten some work done on it, but not nearly as much as I would have liked. I was seriously expecting to be driving it by now, but stuff happens.
I have gotten the motor and trans mounted (327 / th350). Just picked up a set of rams horns exhaust for it and have the rest of the dual exhaust ready to go on (when I make the 90 degree from the manifolds down). I have all of the brake lines run and finally have the master cylinder / brake pedal assembly mounted where I need it and where it will work (long story on that alone....maybe later I'll get into that). The one thing that does have me happy is the interior. I picked up a complete tan leather interior from a Bonneville SSEi. Full power with all of the controls and wiring harnesses, console, shifter and lots of other little parts and pieces.....got it all at the local "U-pull it" for $40...plus about 3 hours of my time. The front seats, when I set them in, lined up about where the orginal seat tracks mounted, everything fit like it was meant to be there. I can sit in the drivers seat and look straight out the middle of the windshield and the leg room is working out better then I could have hoped (I thought the leg room would be more cramped like it was in my 39 Plymouth). Here is a pic of the seats right after I threw them in to "test fit" them ![]() I've been working out the details with the dash....I wanted the original look of the dash.... ![]() BUT...I wanted the reliability and accuracy of newer gauges.....I found a set of 2" diameter gauges and have been adapting them to fit behind the original bezels (I promise to have some pics or that as it goes back together). The numbers for the speedometer and the other guages were cut out of vinyl and the font matched the original design real closely. I'm also having a custom gas tank made by a guy in our car club (he does a lot of pressurized tanks for big companies, so I know he can make one that can hold some liquid)...actually should have that by the end of the week. I still have to do the tin work inside and around the firewall, then install the seats perment, and do the wiring and I still need to get the front glass cut, along with probably lots of other things, but for now, I'll throw a couple of pics out, and once I get some to the other things going back together, I'll get some more pics for you guys ![]() ![]()
Thanks for the update. Those seat look real comfy. The ones in my 50 are from a 03 Trailblazer, leather 6 way also from the local u-pull it along with the console.
I mentioned in the original post that I had more build pics on my old computer that died...well I finally got around to buying a cable to down load the stuff from the old hard drive on this computer and figured I'd throw a couple more of those out today.
These are the first fitting of the S-10 sub to the farctory frame....it gives you an idea of how I had to "adapt and over come". Notice in the first pic how the S-10 trans mount had the lip that we notched the factory frame for it to slide into... ![]() ![]() The next pics are of the 3x2 tubing that was slid into the factory frame to give lower support to the sub. Also you might see that the notch on the drivers side in the factory frame was moved upward so that the car could be lowered some more when the sub was slid in. ![]() ![]()
Bookmarks |
Thread Tools | |
Display Modes | |
