It has been talked about many times. If you don't know how do something get help from a pro. It's okay to learn to do stuff but ask questions and get someone to look over your work if you are not sure. DON'T put your life in danger or the life of others. This set up could have easily broke the mounts and had the engine resting against the the open steering knuckle it has. At that point it would be a guessing game as to who you were going to run into. I started to cut through this but thought I'd check. I scored the welds a little with a cut off wheel and then smacked it with a hammer. The mounts went flying.
