Go Back   Rat Rods Rule / Undead Sleds - Hot Rods, Rat Rods, Beaters & Bikes... since 2007! > Builds!
Old 07-05-2015, 06:09 PM
skull's Avatar
skull skull is offline
''SARCASM: just one of his many talents.''
Default 1935 vintage modified turned street legal race car 0R here we go again
a vintage modified is a modern oval track chassis with a 1948 or older body.
this car has wilwood four wheel disc brakes, 3-link rear suspension with ford 9 inch, 198O camaro front clip with all trick parts, nasty SBC 35O and manual trans.
several of my friends seen the vintage race car l am putting together and wanted one, this one is being done for one of the friends but he wanted a car like they race today, not like mine built in the spirit of the 196O's and this one was raced all over the NW for the last 6 years.
this one should not take long, not a lot of reworking like we had to do on mine, basically lights, turns signals, horn, street legal tires and titled & licensed leaving the paint alone so that should about do it.
Later
my opinion only, valid where prohibited, for official abuse only.
1928 maxwell hybrid build/drag car
http://ratrodsrule.com/forum/showthread.php?t=37455
1948 dodge truck in deceased son's memory.
http://www.ratrodsrule.com/forum/sho...odge+truck+son
1930 2dr mopar.
http://ratrodsrule.com/forum/showthr...ht=30+mopar+dr
Old 07-05-2015, 09:53 PM
Torchie's Avatar
Torchie Torchie is online now
Old 07-05-2015, 10:29 PM
smallfoot's Avatar
smallfoot smallfoot is offline
That'll be fun!!!
Old 07-06-2015, 04:50 AM
You've started a trend Skull!
Old 07-06-2015, 08:01 AM
You know that you're going to end up with 10 to 12 of those running around and you're going to end up having to put on an exhibition race at the local track
Old 07-06-2015, 07:45 PM
skull's Avatar
Default progress today
parts on order: alternator bracket , wheels, 3.5O ring & pinion with a complete rebuild kit for the 9 inch,headlights with built in turn signals with brackets and a EZ wire harness.
l got the seat and a new one wire alternator today, tomorrow going to semi-truck chrome shop for some L E D tail lights they got some real nice ones already on a brushed aluminum plate or a diamond plate one.
Later
1930 2dr mopar.
Old 07-06-2015, 07:52 PM
Sniper's Avatar
Sniper Sniper is offline
Canadian Rust Bucket
Going to even it up, or leave it all offset?
If you can't be an example.....be a warning.
Old 07-06-2015, 11:15 PM
skull's Avatar
Default leave
my buddy who were building the car for likes the offset look, so it will stay the way it is, which is good, makes less work for me.
these cars are alot of work to do so any time l can not re-invent the wheel is fine by me
Later
1930 2dr mopar.
Old 07-07-2015, 11:51 PM
skull's Avatar
Default today
we got the door off to be able to get inside to work on the seat and put in the brake pedal switch. big ol'e plate to keep debris from getting thru the door panel into the driver.
there was about 2OO pounds of lead we had to remove, those circle track guys sure like there ballast.
went to the semi truck store and found sequential cool looking turn signal and brake light L E D 12' X 2' bar lights and L E D running/tail lights.
Later
1930 2dr mopar.
Old 07-08-2015, 08:59 AM
Coming along real good!!!!!!!!!!!!!!!!!!!!!!!
