Old 08-02-2020, 11:20 AM
Originally Posted by zzrodder View Post
It's done with glass bead, not so aggressive as sand, and less chance of warpage. My guy did a car for the Rust Bros, but the producer said he was too expensive so they found a cheaper alternative. I believe you get what you pay for....
This body was soda blasted many years ago but had been kept in a drippy shed on the coast until it came to me so the primer it had on it was almost lost to the elements..
Thanks zz. I'm sure your guy knows what he's doing and he's priced accordingly.
Here in the bread basket, I doubt we have any such specialist. A good friend once said (in total frustration), "If it's not farm equipment, you can't buy it in this town."
Old 08-02-2020, 02:15 PM
Torchie's Avatar
Torchie Torchie is offline
Kind of the same around here Crank but it’s oil field equipment. The guy that does my snow plowing works for a company that does lots of things like sand blasting. They might be good for a frame but I would never let them do a body.
. That’s some serious dents there. dutch.🙀
Old 08-02-2020, 05:56 PM
zzrodder's Avatar
zzrodder zzrodder is offline
Originally Posted by dutch View Post
looks nice! blasting sheet sure is a trade.
here`s what happened to a tractor hood a customer had blasted... it first came in for some rust repairs...turned into a bunch of hammering...
That would be irritating to have something you pay for ending up giving you a bunch more work...
Old 08-03-2020, 02:16 AM
dutch dutch is offline
Yes it would,turned out a bit more expensive for him. I did warn him before...
Some of those waves were 8mm deep and that was 16 gauge material.
Old 08-03-2020, 06:52 PM
kenny c kenny c is offline
OUCH!!
Old 08-10-2020, 10:00 AM
zzrodder's Avatar
So I decided to go with the parts from Bob Drake for a 41-46 Ford for the wipers
The Ford kit is 3 1/2" narrower tyhan the Packard so I had to widen the transmission mount bar and the link arms, also flip the motor mounting to tuck it up under the dash out of the way of electrical, etc.
Had to shorten the wiper arms 2 1/2" to work with the window size, shorter that the Ford, plus it has been chopped. Drilling the holes in the cowl was the easy part...
Naturally, no gain comes without pain... the wiper transmissions end up right in the way of the defroster ducts from Vintage air that I had fitted with studs welded to the dash underside - I'll need to make all new ones to
fit tight to the dash to bring the hose connections away from the wiper linkage.... Oh Boy, more fab work
Old 08-11-2020, 11:36 PM
zzrodder's Avatar
Came up with this header tube to direct air to the defrost vents in the dash, grafted on part of the Vintage Air ducts with screws and some JB Weld.
Mounted under the dash, the wiper linkage just clears at both ends.
Old 08-11-2020, 11:40 PM
zzrodder's Avatar
After media blasting, what I thought was just one or two holes in the headlights turned out to be some serious cancer
Couple hours of welding and grinding later, no more holes..
Old 08-11-2020, 11:52 PM
soltz's Avatar
soltz soltz is online now
The Rat Captain
Thumbs up
Nice work
What's your magic
Be Safe
and
Be Creative
Old 08-12-2020, 05:19 AM
Good work around on the defroster vents.
Rust never sleeps
