![]() Treatments were applied to original rust and paint on a 47 Ford Jailbar cab section. The first pic is immediately after application, while the second pic is after 71 days outside. For the first few days, FF is too shiny for my taste, but not bad later. PBB keeps much more of the original rust look. PBB is much easier to apply than the thick FF, but its water beading capability does not last near as long. After over two months, FF still beads water. The third pic is after a single treatment of phosphoric acid (Ospho). Phosphoric acid converts iron oxide--rust--into inert ferrric phosphate. As can be seen in the pic, exposed rust is turned white. What surprised me is that it brought out color in the 73 year old paint. PBB is easy to apply with a spritzer. Excess can be wiped off with a rag. The odor is an effective "social distancer!!" But the odor goes away if left in the sun for a couple of days. FF is much more pleasant to use, but takes more effort and time to apply. When I built my 56 Dodge about 5 years ago, I first used CLR and a random orbital sander with a medium Scotch Brite pad. It makes a very messy slurry, but brings out paint that is covered by surface rust. Since then I have treated the truck every few months with PB Blaster (PB). PB is easy to apply with a spritzer, then wipe off excess. Anyhow, I am switching to FF. The experiment continues, and I have started a second experiment with a first Scotch Brite treatment of CLR and PBB followed a few days later by FF.
Low & Slow 56 Dodge truck build http://ratrodsrule.com/forum/showthread.php?t=33336 http://www.peachparts.com/shopforum/...-om617-10.html 1939 Plymouth sedan build http://ratrodsrule.com/forum/showthread.php?t=37129 |
Thanks for sharing the info and your findings.
Glen My 29 Essex Build http://ratrodsrule.com/forum/showthread.php?t=34026 Don't give up, it's far too much fun once you can drive it. |
Look up "Gibbs oil",Seems to work pretty good but haven't had it out in the weather to check longevity.
![]() Quote:
Just passing along what I learned from my limited test.
Here are results of a second experiment.
Initial treatments were CLR, Nothing, and Ospho (phosphoric acid), L to R in the first pic. This was followed 12 days later with Fluid Film (FF) applied to all. The second pic was taken 3 weeks after the initial treatments. Surprisingly, Ospho brought out a lot of color from the 73 year old paint.
If you want something shiny like that, just wax it. Trust me, it works great.
My 455 Buick powered '46 GMC Build Thread My '46 GMC on Photobucket --------------------------------------------------------------- When you don't know what you're doing, it's best to do it quickly. And when I’m gone, you can call me foolish but hopefully not boring. I will have lived. The more I learn about women, the more I like my car. |
![]() Quote:
Here is an update, with pics of the first experiment after 140 days, and the second experiment after 90 days. Third pic is of Ospho after 105 days.
All have been outside from day 1.
Just another update. Here is the second experiment after 180 days outside. I'm amazed at how well FF holds up.
Bookmarks |
Thread Tools | |
Display Modes | |
