Builds! Post your project here... show us what you're up to! Please Note: This section is for "Builds" ONLY! |
Thread Tools | Display Modes |
![]() Here are a few "before" pictures of the car, interior, firewall and trunk. Lot of rust to deal with.... |
Before shots of roof (after stripping primer) and front suspension. The previous owner claimed the car was ready for paint. Don't think so!!
AFTER shots of the interior and trunk..... Basically fab'd my own pieces from flat steel and welded in w/ MIG. I AM NOT a welder by any stretch and blew a lot of holes in the worn out metal..... I am curious how many welds will pop when I torque the frame with the new SBC.
AFTER shots of the firewall. Smoothed as much as I could by welding in holes and using a little bondo skin. Then primed it... I did the same w/ the inner fender wells. I plan to paint the engine compartment body color and then drop in the drive train so I can start enjoying the dude while I'm working on other body stuff.....
AFTER shot of the roof. It's in acid primer and a little high build. This was a freaking mother to strip all the rust off. I actually primed the thing 2 times, only to have to strip it all again and redo it..... Still working, but dragging my feet a little because I really, REALLY, REALLY want to chop it. I really like the look of HOITINK's build - I like his chop...... The second picture is my "gut check" tape mark for a chop.... I have never done that and am not a proficient welder by any stretch...... A real gut check.....
AFTER shot of front suspension. Basically stock, but replaced uprights w/ 2" dropped Fatman's. Also installed Jamco disc and cut coils and stabilizer. I need to figure out the steering, but plan to stay stock for now. I really want to bag it, but will do that w/ stock suspension as well. The rear suspension has been redone w/ de-arched leafs and Ford 8.8". Plan to run SBC, 700R4 and 3:05 rear end... I would really like to c-notch and bag the rear as well, but not sure about my proficiencies for that. I have also heard that the tophat frame is not good for welding on due to stress cracking potential.
Some tricky rust repair in the corner of the door frame..... Also working on filling in holes where won't be installing trim.....
Here's my engine builder....
Here is my goal, but I will probably go darker on paint now. I love this car. I am doing the grill similar to this - requires some welding and fab work..... I also want to pancake the trunk like HOITINK's build - very sweet.
I have learned that you don't take stuff to a hot rod shop if you don't want to pay through the freaking nose!!!! Cost me $1000 to get 3 pieces blasted, worked w/ acid and epoxy primed...... Never again. |
Nice work. Look forward to following your build. Good to see you have a quality wrench buliding the motor. Father/son projects are cool.
Driving Yesterdays Rides-----Today ! '47 Plymouth Coupe - mine '47 Chevy PU - wife's wiring Aerodynamics are for those that can not build engines. - Enzo Ferrari |
Bookmarks |
Thread Tools | |
Display Modes | |
